Bumper and tailgate Question
right, similar theme to my thread in exhaust section
buying a gt coupe at the weekend but it has a smoother bootlid and numberplate relocated to the bumper, not my cuppa so i'll be returning it to standard
what bootlid can i use? any mk 3 polo coupe or are the gt ones different?
what bumper can i use, same thing are the gt ones specific or not?
and finally how is the boot loom attached, is it a multiplug, so will i be able to loose the hacked together bumper loom and reconnect a standard loom when the plate is back in the o/e boot recess?
any info much appreciated
thanks
  • Views 741
None of the parts are GT specific so no probs there.
For the wiring, cut the plug off the tailgate loom inside the passenger rear 1/4 panel and feed it through the pillar. Solder it back together when you've refitted the new tailgate. The plug won't fit through the hole in the pillar hence why you need to cut it off. Trust me, this is the easiest way of doing this.
good news
and cheers for the heads up on the loom issue
