breaking 1.4 16v
still got some stuff left off the mk4 1.4 16v, afh engine code
cylinder head, 3/4 bent valves, £40, will split, cams or bare head
front brake setup(discs pads calipers and carriers) £30
ecu, transponder ring/box/keychip £20
clocks, displaying 118k, small crack in the clear casing but un noticable when fitted, £10
inlet manifold £20
black dash and doorcards £35
dizzy £10 (needs new rotor arm, costs about £4
water pump £10
alternator £10
midsection and backbox, good condition with no holes, one mount has broke off but ill weld it no bother, il strenghten the other mounts while I'm at it, £30
airbag £10
injectors £10
starter £10
40mm springs, bit scabby, £20
rear axle £30
power steering rack £30
ignition barrel with key and matching doorhandle(saves hassle of 2 keys) £10
outlet manifold £10
1.4 8v engine 92k, £60, will split head or bottom end if needed
pics upon request and all offers considered
cheers, jim
edit, some pics added
springs
http://i18.photobucket.com/albums/b137/Jam...11052009018.jpg
http://i18.photobucket.com/albums/b137/Jam...11052009019.jpg
injectors
http://i18.photobucket.com/albums/b137/Jam...11052009023.jpg
exhaust
http://i18.photobucket.com/albums/b137/Jam...12052009024.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009025.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009026.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009027.jpg
doorcards
http://i18.photobucket.com/albums/b137/Jam...12052009028.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009029.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009030.jpg
http://i18.photobucket.com/albums/b137/Jam...12052009031.jpg
inlet manifold(throttle body not included)
http://i18.photobucket.com/albums/b137/Jam...n/engine002.jpg
http://i18.photobucket.com/albums/b137/Jam...n/engine004.jpg
cylinder head
http://i18.photobucket.com/albums/b137/Jam...n/engine007.jpg
http://i18.photobucket.com/albums/b137/Jam...n/engine008.jpg
http://i18.photobucket.com/albums/b137/Jam...n/engine009.jpg
brakes
http://i18.photobucket.com/albums/b137/Jam...06072009067.jpg
http://i18.photobucket.com/albums/b137/Jam...06072009068.jpg
http://i18.photobucket.com/albums/b137/Jam...06072009070.jpg
http://i18.photobucket.com/albums/b137/Jam...06072009069.jpg
Edited by J1M MK4
  • Replies 43
  • Views 2.3k
you got pics of the exhaust and door cards also where you based?
I'm in glenrothes fife, i can get pics of doorcards tomorrow and if i can get time ill take the exhaust off, cheers
got throttle position sensor?
if so how much?
cylinder head, 3/4 bent valves, £70, will split, cover, cams or bare head
brake setup(discs pads calipers and carriers) £45
ecu, transponder ring/box/keychip £35
clocks, displaying 118k, small crack in the clear casing but un noticable when fitted, £15
inlet manifold £30
black dash and doorcards £45
dizzy £15
water pump £15
alternator £10
midsection and backbox, from what i can see its in good condition but cba taking it off if no-ones interested in it, £30
airbag £10
injectors £10
starter £10
40mm springs, bit scabby, £25
rear axle £40
power steering rack £40
ignition barrel with key and matching doorhandle(saves hassle of 2 keys) £15
outlet manifold £20
1.4 8v engine 92k, £80, will split head or bottom end
cheers, jim
hi you got the throttle body if yes how much??? and how much for roca cover posted to manchester????
£20 posted to manchester for the rocker cover seeing a it will prob cost around £7 to post, cheers
you got the gearbox from this dude?
16v throttle body?
if its not listed iv not got it(unless its something random that I'm unaware exists tbh lol), sold most of the stuff earlier in the year, cheers
Pics of springs and backbox? may be interested, depends on how "scappy" looking they are! lol
jamie 300, springs arent that bad just the red coating has started to peel a bit and a bit of surface rust has started to show, the pics on the link are of the "scabbier" side, still structurally sound though
polojack, doorcards have been sitting around for a bit and iv not had time to clean them before the pics so they're better looking than in the pics
Edited by J1M MK4
all pics requested are now on photobucket, for some reason I'm not allowed to send any more pms for 24 hours so if youre waiting on a pm from me then bear with me
http://s18.photobucket.com/albums/b137/JamieDuncan/
jamie 300, springs arent that bad just the red coating has started to peel a bit and a bit of surface rust has started to show, the pics on the link are of the "scabbier" side, still structiorally sound though
You selling the lower wishbone just under the ball join gaitor for the driver's side?
Edited by Mike1990
how much for the door cards posted? If 3 door. Pm me with a price i'm sure we can work something out :)
boss, 35 and you arange courier, tht way neither of us gets bumped with trying to estimate a postage price
mike 1990, iv still got it but i think its rusted to fk, ill check tomorrow, check here for a reply cause for some reason I'm not allowed to sent alot of pms
have you still got the air flow sensor / throttle body sensor?
sorry matt not got either of them, cheers
Hi mate, how much for the rear brake drum posted if its still going
gearbox? if so is it cable change?
16v bumpers front and rear?
make the drum 15 posted if its just the one youre after, 27 if its the two,cheers, no gearbox or bumpers as iv alreay stated if its not listed(unless its something so random I'm unnaware it exists) then its not there
get the offers in, wanting rid of this stuff its just junk to me tbh....
maybe glass sunroof left somewhere? actually i need just glass. thanks
price drop on nearly everything
what year was the car mate?
P reg, 97
