polo 6n rear wiper
what position on wiper stalk on a 6n makes the rear wiper to work, as it just wont work whatever i do,
  • Views 1.5k
on the earlier models, pushing forward on the right hand stalk, holding it forward to spray water
on the later models, pushing the little button on the side of the right hand stalk
its a button on the end of the wiper stalk.....press it in = on, out = off :-)
Edited by Dub Life 7
mine is the early type it will spray water if pushed forward, but rear wiper wont work is it more likely the switch what is faulty, or the rear wiper motor which is knackered, is this a common problem on these cars
Sounds more likely that motor is knackered if it will spray water. May be worth checking that the wiper arm isn't loose on the stub so its just staying still instead of moving
Not a hard job to replace the motor though, just remove the wiper arm, and then the nut on the outside, then just remove the boot lining and the two bolts holding the motor on and should pull out.
thanks goose will have a more thorough check over the weekend
I also have an early model of 6N and i had same problem ... i solved it by checking the connection (it was a bit loose) under rear post cover, near the back bench security bolt.
On early models you need to push wipers switch forward to switch it on, and push again to stop it.
if you need a motor i have one you could have....let me know after you have checked the connections etc...
