steering lock removal polo 6n
i am trying to remove steering lock on my 6n as there is play in the bearings i have removed the shear of bolt , but i cant remove the splined adapter of the steering column , i have tried 2 and 3 eared pullers and nothing works as soon as you tighten the puller it just slips off as there is hardly any lip for the puller to get any purchase , what is the best way to remove this , or do i need to cut this off and is the part easily available new from vag or gsf, when it comes time to refit everything
  • Views 1.2k
up
post in the right section you might get a reply then?
what is the right section , interior, engine,
up
