quick steer kits
does anybody make 'em for the mk3 polo?
any help please :-D
  • Replies 14
  • Views 1.9k
you mean a quicker steering rack (less turns from lock to lock)? No I've never seen such a thing for a mk2/3 polo.
Quaife would do it if you had a few people for a group buy, it's quite easy to persaude them to make you something if you've got enough buyers :lol:
They do one for LHD polo's but not RHD
Ultimately, it would depend on the price of the kit.
Why would you want one on a polo though?
oh well just a thought, i had a go in a mini that one and it was good :-)
the owner said hes not going back to normal steering now.
Get a steering quickener from the states. They're a planetary gearbox that sit inline with the column. Various ratios available.
You'll be wanting a front wing next and side pods F1 stylee :lol: (sorry, had to say it!)
The only place i can see ithelping is in a carpark tbh. Be interesting to see though how much they'd want for a kit.
Would help if you were making it into a track/rally car...
Edited by goose
Quick Racks can make the steering more responsive... also on corners it can mean you might not have to take your hands off the wheel to get round it and can give a car a more sporty feel. I would have one if they did it in RHD... but I'm interested in these steering quickeners :)
suppose on a trackcar it would be good.
More info anyone/web links?
So what do they actually do?
They quicken the steering.. basically the same as a quick rack. Unless I have totally got the wrong end of the stick.
E.g for the one listed every 1cm you turn the wheel the output is like you have turned it 1.5cm.
So rather than getting a new rack this is placed in line with the steering column and you can use the standard rack which has the same effect as a quick rack.... i think :)
Edited by max_crox
Exactly. Bit like an overdrive unit,you find them between the propshaft and gearbox of some old BL cars amongst others.
Basically,its a geared shaft,so if the input shaft turns one revolution,the output shaft turns say 1.25 revolutions. With a steering column version (much smaller and lighter),turn the steering wheel quarter turn,and whilst the upper steering column turns a quarter turn,the lower half of the column is turned a third of a turn.
Its a gear on the column then,giving you go-kart steering - but obviously this makes the steering wheel itself stiffer,because extra effort is required to turn the steering wheel the same distance.
I dont fancy chopping my collapsible column up for it. I think the standard steering is okay,but i could be interested in a proper quick-rack conversion (maybe just the internals) if a group buy came up,and the gearing drop was mild.
