which polo?
  • Replies 14
  • Views 1k
Looks like a 1.0/1.4/1.6 Mk4 one
i would say the same as tobyk.
will it if a mk2/3 thought ???
i've got one of those without the cutout for the throttle cable on my g40
it would look a lot better with out the cut out
get some pic's up
but would this fit a 1.3 mk2 engine
As requested, picture is about 4 years old now!
its the same as my 6n 1 litre. the groove is for some cables iirc
yeah, i had one but it had the groove init
try get one without them!
Well it says in the advert it will fit a Mk3 and I think the rocker covers are the same for the 1.3 and the 1.05.
Edited by Sii
It should fit!
The bolt seats on engines with that cover are higher on the camshaft bearing caps,and the seal seats differently,requiring the different caps to fit properly.
The caps are matched to the head,so you cant often swap them or the camshaft bearings wont carry oil and you can get engine failure from that.
But the gasket still seals properly on the shorter and grooved caps - the cover will fit and seal fine on a steel cover engine if you just fit it with care and only torque the bolts tight enough to seal,but not as tight as they'll go (or you may crack/bend the cover).
i have one of these with the cable slot , 15 pounds plus postage
kam off here got mine for me. 5 quid, then postage
£60????? bit steep aint it??? i got one with the cut out and one without sitting under my bed for £15 the pair from the scrapyard. Half polished but getting there slowly, going to stick the non cutout on my car when its done.
