First car! '96 6N
Got my first car on Friday. Polo 6N 1.4 SE P-reg. ^_^
She's not perfect, but I love her. I'm still 16 so can't drive on the road (legally...) yet [17 in a month today], although I live on a farm in the countryside so I have a drive I can drive up and down our track and a yard to practise 3-point turns. So far so good. Tractors are scary though...
Cleaned her today, and went around looking for problems. Before I made the purchase I got a local garage to have a look over. They said the coolant housing is leaking slightly, but apart from that nothing major (slight gearbox oil leak, a belt [forget which] slightly cracked, the bushes just starting to go), and very minimal rust. I've noticed the clutch needs a large depress and the handbrake needs to be pulled up a long way, but I'm hoping to get it taken into the garage soon and have some things tightened up. There are a few more non-engine problems too, but nothing serious.
Would anyone here be willing to give me some advice on repairs, such as if it's OK to do yourself, or how much they would cost?
Problems I've found so far:
- Near side mirror electric doesn't work [Either wiring broken or just unhooked?]
- Near side side indicator is slightly loose [Just needs refitting/tightening? Still works fine]
- Near side dash speaker slightly raised in one corner [As indicator]
- Near side front lock pin top snapped off [A whole new system needed or just pin? Hard to fit?]
- Near side front door speaker cuts out when door fully open [Wiring problem?]
- Aerial is a bit dodgy [Just buy another screw-in one if I want]
- Wiper blades need replacing [Just blades or full arm?]
- Fuel lid has no spring [Just spring or full cap?]
- Radio doesn't work [Previous owner said something about a cheap valve (he didn't know much about cars he said)]
As you can see, nothing major (mirror is the main thing).
The previous owner(s) had lots of those glass sticker things. When I got it there were two. One came off easily, although the other is cracked and is almost baked on. There are also marks from where others were, and they're really annoying me. I've also removed the tax disk holder, and that's left some gooey stuff. What's the best way to remove all this crap?
Also, what are the "standard" specs for a '96 SE?
I'm not looking on doing many mods due to money (or lack of). I'm probably gonna get a new head unit and speakers. Maybe clear side indicators? If I can get a job, some alloys too (although need to find out about the fitting - I've heard it's 4x100 35-38mm?).
Any help is hugely appreciated!!
Edited by Drakelet
  • Views 813
Welcome :-D
to get sticky stuff off use a hairdryer.
yeah 4 x 100 and et38
welcome to cp
Firstly, welcome to ClubPolo!
About the door pin...it just screws off, you dont need to change anything else. They're pretty cheap, around a quid each i think...
Ussy
Thanks guys!
