Lowering Seats in Coupe GT
Just bought a H-reg Polo coupe GT. Problem is I need the seats to be a little lower to be properly comfy, as being 6'5" it's a touch snug!
Has anyone got any top tips or pointers?
Alternatively is there a way to make the sunroof tilt rather than slide?
Thanks in advance for not mentioning how stupid it was not to check this before buying! However I just fell in love!
Matt
  • Views 1.2k
Corrado front seats go in pretty easy and sit much lower than the Gt ones
seats from a mk2 scirocco also fit i think and sit lower
yep corrado or scirocco seats are good to put in a polo, used to have corrado ones in my old gt breadvan, much comfier for driving. Scirocco ones are basically the same but with different material. You can get Scirocco seats in the same material as polo genesis seats which means if you get them and a genesis rear bench then they match,
Thanks guys, will they fit straight in or require fabrication of mounts etc?
Matt
they slide straight in, scirocco seats with the large bolsters are very good, but its difficult to find a pair that arent torn.
As Pete suggests; the scirocco seats sit a fair bit lower than the polo seats, are wider and fully adjustable!
Superb, hopefully save me the cost of a set of buckets. I need about 2-3 inches, you reckon they sit that much lower?
