Cleaning a Gearbox?
As title really, want to clean up a gearbox, possibly for painting.
This is as clean as it will come with petrol and engine de-greaser:
As you can se, still an awful lot of grime and corrosion
Any suggestions?
  • Replies 16
  • Views 1.6k
wire brush degreaser and gunk worked it in and came out mint for me
could you put that nitromoors (dunno how to spell it) to clean it up abit
or strip it and shot blast it??
Thats the problem, i dont really want to strip the box. Theres not really paint on it so nitromores is out, will try a wire brush tonight though, its just all the fiddily little bits you cant get to!
strong alloy wheel cleaner or brick acid...work it in with a small wire brush or scotch pad
repeat until its tidy
give it some good wiping with a degreasing spray and bang loadsa hammerite on it should be fine pal
i would say use a wire brush and see what happens
Get into the fiddly bits with an old screwdriver. As other post soak with gunk. Worked on mine. Depends how good a job you want to do
What a ball ache! Its just not coming up how i want it to!
give it a good spray with carb cleaner and then get a pressure washer on the go.
The grease in the CV joint, does it matter if that gets washed out? Is it special stuff or can i use basic Castrol grease?
bump before i get the pressure washer on it
its called moly grease i think ...will say its for c.v's etc on the tin
I purposely wash it out and then replace it with new. You need to use specific CV grease, sometimes called moly grease. It's usually black and has different properties than general purpose grease at higher temps.
I've cleaned several gearboxes using the carb cleaner and pressure washer method either prior to painting them or just before fitting to a car to make them look cleaner. Takes about 10 minutes, you will get wet though as water splashes everywhere.
POLOMON : very nice but that must've taken all day with wd40, wire brush and sand paper!
Seems obvious,but dont spray any seals with the pressure washer (release arm,main shaft,remote,end plate or driveshaft flanges) as water can get through.
Diesel and a washing up brush.
sand blast?
