Bumper Smoothing
Right.....I've recently got myself a replacement rear bumper (it came with some scuffs and has a little crack in the bottom which I'm going to fix, probably melt the crack with a soldering iron or fibreglass it, not sure yet) but anyway back to the main point....
progress on the bumper is not much lol, after i got home from my exam i managed to get both of the bump strips out, took about 20 minutes to get both the left side and right side out, once i got a couple of clips off i found a method to take the rest of easily and quickly lol
Tools Used (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
Before (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
In Progress (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
After (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
next step is sanding the area where the bump strips were (the black bits) and the area around the bump strips
can anyone give me any advice ? should i plastic weld in some plastic and recess it a bit so that i can fill on top (after sanding of course) or shall i just go all out and use body filler/bumper filler or fibreglass and slowly build it up and then prep for paint ?
i thought i might aswell give it a go and see how hard it is to smooth a bumper plus i wanna learn how to do it, so I'm kinda teaching myself lol, the recess on the 6n2 bumpers aren't as deep as the recess on the 6n bumpers, i thought they would have the same kind of recess.
but anyway, ill keep you all posted on the progress, tomorrow i should be sanding the whole bumper, getting it ready for filling
cheers for any help/advice anyone can give
Edited by SoniC6N2
  • Replies 43
  • Views 3.9k
Nice guide mate :) would really help someone who needs to smooth there bumper
cheers mate =)...
I'm just stuck with one little bit now, dont know how to build up the different layers so i can blend in the recess with the rest of the bumper, thinking about using bumper filler (its the same as normal filler, just a bit more flexible) the only problem is i dont know wether i should plastic weld or build up the filler and fibreglass...thinking and trying to research what would be easier and give a better finish
ill post my progress here anywayy...
plastic weld it then i always usu a JD weld type stuff over to stop it cracking more then abir of fubre glass filler to get in bit bits then filler
, always worked on customers cars
@jack, please proof read your reply :lol:
I'm interested , but cant make out a word youv just said
Edited by chrisbin
looool
i kind of understood it loll...i think he basically means to plastic weld it then i dont know what he said lol and then he said fibreglass it and then filler it lol
yeh, i wanna know what this jd weld type stuff is hes going on about.
btw, you cant go wrong with david isopon p38 body filler :nod:
I think he meant plastic weld it then use some JD weld type to stop it cracking
JD Weld type ? confused. loll
yeah there was a thread on here of some-one doing a 6n bumper they plastic welded the recess and then recessed it back a bit and then fibreglassed and then filled on top, if thats understandable, thats how i want to do my one
Edited by SoniC6N2
I'm not sure myself lol
Could be this?
http://www.repairproducts.co.uk/page42.htm
smooth the rear bumper and sell to me!!!!!!?? :D
not wasting time the Medzy :)
only dropped it off to u end of last week, thought u were gonna start in summer LOOL
Looking good though
Babz
Looking good though
Babz
lollll yeahh...i got ahead of myself haha...i wanna get the bumper done and then i need to do the front one and then need to slam the car, then ill start bringing it to meets lol...if i do it well enough i might end up doing some for other people, ill see what happens though, ill start sanding it today/tomorrow and then post up some more progress in here
Lolll...lets see what happens Jack_16v lol
Could be this?
thats odd, doesn't the filler need to be flexible ? this one says its gonna go rock hard :shock:
Edited by SoniC6N2
LOLZ
sorry lad
was in a rush hahaha
right ill start again
i get some plastaic and cut it to the same size as the hole (also has to be the same plastic as the bumper or itll not weld)
try and get the plastic as close to the edge of the bumper means less filling and less likely to crack
anyways i tack it into place with odd spots with soldering iron or plastic welder
next melt excess plastic all the way around the bit thats gettin welder
sand it down to get all the crap bit off then add abit of JD weld over it to give it a bit of strenght,
flat that down again
if tehre any big dents front wher eit hasnt fitted probly put a light skim off fibreglass filler in
smooth that down
then i use elastic filler, fill over it with a decent coat, check that it smooth and trying to keep the contoor of the bumper
give the bumper a good grey scotchbrite and smooth off the sanded areas with some 180 grit then 320 and give it nice coat of plasitc filler primer anmd flat down with 600 or 800
then paint
if youve doen it right itll look nice and standard
done this meathod a couple of times on a customers car
thank you please
was that better? hahahahhahah
LOLZ
sorry lad
smooth that down
then paint
thank you please
lol thats much better, ill keep that in mind when i do mine =) I'm considering cutting down the bump strips i took out and using that to put into the recess
dont think itll be big enough
it wants at least a 1mm gap between the bumper and the plasit your welding in you your gunna be there forever welding and itsmore likely to crack
I've been reading round and apparently you can use any kind of plastic, it doesn't necessarily need to be the exact same as the bumper
you want it to crack? then use any plastic
use the same plastic, its less likely to crack
I've learnt from my mistakes mate
course i dont want it to crack, just saying what I've read, not like I'm going to follow that though lol, haven't even sanded the bumper yet!
noooooooooooooo all wrong :-D i would'nt plastic weld as for if not done write then its not effective at all id make sure you prep the bumper 1st and sand the area your smoothing realy well with an 80 grit or somthing harsh to start with then id fill it full off fibre glass ( the paste not the strands) warm it to dry well or wait for it to dry then usin the 80 grit or what ever you used to sand the bumper down use that to take down the fibre glass down then use filler to finish it off aply a guide coat and sand that off usin a 180 grit usin a flat block and keep block flat as you remove guide coat ( this will show you if theres any wobbles or low spots as for there will still be guide coat left and will also remove harsh scratches so then this will be primerble ) if your left with guide coat just keep aplyin filler take it down slightly and aply guide coat and do it again :-D intill smooth and correct
then high build primer plentty off coats and then a guide coat and use 1000 wet and dry paper ( usin water with this ) and a block and remove guide coat again :-D but if usin flick can be carfull as for if you apply to much primer at once you will get solvent pop an thats a idiot haha but if done write youl be left with a nice smooth and primed bumper
this is how i done my mates and i work in a bodyshop and it hasent cracked 8-)
hahha its alright mate
do it the proper way, by plastic welding
or you could bodge it like most places do and slap load of fibreglass filler in a hope for the best hahahaha
ill keep a look on this tread or pm me if you want anymore info as I'm not on here much anymore ,and get it done ;)
if plastic weldin and all goes good then id drill holes in the plastic you have weldin in so it gives the fibre glass or filler some to hold to :)
jack1 : plastic weldin is good and the best way to go about it but like this dude has said hes never done this befor so if not done propper then plastic welds will crack and out comes the filler i was going to plastic weld my mates bumper but desided fuck it just slap in the fibre glass still does the job and is just as good :thumbsup:
personally i woudlnt recoment blasting load of fibreglass filler in,
had to redo a few that cracks from fibreglass filler,
nobs from the local college did them and look complete gash too hahahaha had to scrap them bumpers and have new bumpers
did my mate boras bumpers and still in one pice after 2 years
only got a little crack in after some old woman driving into the back of him hahhaha
not going again yout opion mate
I'm one of them if its getting done then its gettin done properly person :D
I did mine with Upol fibre glass filler comes in 1L tubes, and Ultima Plastic padding filler. Its not really the fibre glass filler that crack as it is flexible, If you use Ultima filler you can buy it from Halfords. Make sure you use a grinder to grind the plastic down and use P40/P80 grit paper afterwards, then a slight skim of glass filler, but make sure all is keyed even the nuts and crannyd so it has good key for fibreglass to bond to. Then once dry key up with P40/P80 an use surface filler finish shaping with P180/P240. I've done these many of times and havnt cracked at all. I even showed one of the kids i did them for and bent the bumper to show him it won't crack.
Edited by polochris20
