Bumper Smoothing
I did mine with Upol fibre glass filler comes in 1L tubes, and Ultima Plastic padding filler. Its not really the fibre glass filler that crack as it is flexible, If you use Ultima filler you can buy it from Halfords. Make sure you use a grinder to grind the plastic down and use P40/P80 grit paper afterwards, then a slight skim of glass filler, but make sure all is keyed even the nuts and crannyd so it has good key for fibreglass to bond to. Then once dry key up with P40/P80 an use surface filler finish shaping with P180/P240. I've done these many of times and havnt cracked at all. I even showed one of the kids i did them for and bent the bumper to show him it won't crack.
cheers for that info polochris, i think i PM'd you about the bumper smoothing, i heard you did your own and you own your own bodyshop or something like that ? your polo is sweet non-the-less!!!, but what about bumper filler ? i think its called that, they sell it in halfords aswell for £9.99, at the moment I've currently got Isopon P38 and Isopon P40 and I'm contemplating getting the bumper filler, I've heard its the same as normal filler, just more flexible if that makes any sense, i dont know if you could recommend this or not ? if youve heard of it that is ?
i was on the Corsa-C forum and someone recommened to use this, dont personally know much more about it though
hahha its alright mate
do it the proper way, by plastic welding
or you could bodge it like most places do and slap load of fibreglass filler in a hope for the best hahahaha
ill keep a look on this tread or pm me if you want anymore info as I'm not on here much anymore ,and get it done ;)
i cant plastic weld lol I've read up about it, but i dont think I'm going to fork out a shed load for the plastic welder, I've got alternative methods though, heat gun (dont know if that will work) and I've got a soldering iron (thats what i was going to use to "weld" the plastic)
but yeah ill definately pm you if i want anymore info, so far all the help has been good :D
noooooooooooooo all wrong :-D i would'nt plastic weld as for if not done write then its not effective at all id make sure you prep the bumper 1st and sand the area your smoothing realy well with an 80 grit or somthing harsh to start with then id fill it full off fibre glass ( the paste not the strands) warm it to dry well or wait for it to dry then usin the 80 grit or what ever you used to sand the bumper down use that to take down the fibre glass down then use filler to finish it off aply a guide coat and sand that off usin a 180 grit usin a flat block and keep block flat as you remove guide coat ( this will show you if theres any wobbles or low spots as for there will still be guide coat left and will also remove harsh scratches so then this will be primerble ) if your left with guide coat just keep aplyin filler take it down slightly and aply guide coat and do it again :-D intill smooth and correct
then high build primer plentty off coats and then a guide coat and use 1000 wet and dry paper ( usin water with this ) and a block and remove guide coat again :-D but if usin flick can be carfull as for if you apply to much primer at once you will get solvent pop an thats a idiot haha but if done write youl be left with a nice smooth and primed bumper
this is how i done my mates and i work in a bodyshop and it hasent cracked 8-)
cheers for that info mate, ill definately keep that in mind when it comes to filling in the recess
All in all thanks for all the info thats been posted and all the comments =)..gives me real good motivation lol...ill definately definately keep this thread updated as i go along and see what happens
thanks for any future help too, appreciate it
Sonic
  • Replies 43
  • Views 3.9k
i say use concrete works a treate :lol:
good luck with this dude hope to see some finished pictures
LOOL!
quick question people is there an alternative plastic i could use to plastic weld ? or does it have to be another bumper ?, I'm thinkin of using the old bump strips and cutting/sanding them down to size and then welding them in, then a skim of filler/fibreglass on top
no progress has been made today lol...gf came round and weather was shit, progress will be made tomorrow and ill update the thread
I'd assume the bump strips would be adiquate..... Should be made of the same plastic....
if not, i've got a wanked old mk5 front bumper you can have if you'd like ? don't live too far away. :S
Nice to see you doing it yourself.
there you go soni
better than pissing aorund with wankness plastics ;)
how much for that wanked old mk5 bumper ?, where are you based btw ?
For free chap!! FREEEEEE! ;)
In mundesley / Norfolk
Postcode: NR11 8DH
Postcode: NR11 8DH
i would so take it!!, but your over 3 hours away i think lol I'm a lazy bastard lol :lol:
but saying that if anyones got a wanked bumper (front or rear) in london let me know lol
and my check engine light has come on so i need to sort that before i can go anywhere, should be getting that checked out tomorrow
just a quick update
I've sanded one side of the bumper (where the bump strips used to be - the black bit in my pictures on page one) and I've sanded the area around the bump strips started of with P40 and then switched to P80, currently given up for the time being and there probably wont be any progress until after the 21st and 22nd, got exams coming up, ill update this thread as i progress with the bumper
another update, not really bumper related, but I've de-wipered the back lol...not a major update but hey, partial about the the grommet looks so might go onto www.gecleant.de and get another one that sits flush with the rear windscreen, but for now the halfords grommet will do
ill put up pics later
Edited by SoniC6N2
Bumpage, old bumpstrips were used to fill into the recess and i plasted welded them into place, I'm gonna take pics tomorrow and post them up, the car itself is progressing too, coilovers on the way, dewipered rear, aero wipers on the car now and GTi Grill is on the car too
all thats left now is to sand/blend in the welded bump strips and then a light skim of filler/fibreglass, primer and then off to paint =)
pics of progress up tomorrow!
this is how we did mine
Simmy did you just use filler ? at the moment with plastic welding theres TONS of sanding to do!! I'm working on the rear bumper at the moment and when thats done I'm gonna start on the front one, but did u just filler your one Simmy ?
thats fibre glass filler and filler
doesnt look that deep tho like they are on golfs
cheers for that I'm gonna fibreglass filler and filler the front bumper its easier than plastic welding I've found out!!!, yeahh the recesses aren't that deep on these, anyway, heres some pics of my progress
Bumpstrip cut & sanded (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
Bumpstrip test fitted into recess (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
Bumpstrip partially welded (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
Bumpstrip fully welded (click image to enlarge - original image was way too big to put on forum - would take ages to load page):
both sides of the bumper have been done, just got bare sanding to do now!
Edited by SoniC6N2
looks like good progress mate!
top stuff :smirk:
Quick update, me and my mate were sanding the bumper and the plastic welded plastic just dropped out when the bumper was picked up, looks like its onto plan B...aka DJSimmys way of fibreglass and then filler on top
Edited by SoniC6N2
I'm literally in the process of doing my rear bumper at the moment.
The key is it use strips as plastic welding rods and literally stitch them together. Dont worry about going into the bumper as the plastic filler will fill them up and give your final curve.
Il try and get some photos up soon.
Try and not go through the fiberglass route, as i know simmy got his redone if I'm correct and any minor slight bump will lead to cracking.
Show me some pictures of how you welded yours please
Update:
Bumper has been fibreglassed and sanded, ready for fillering tomorrow
Edited by SoniC6N2
