removing 6n roof lining?
as title says hows it done?
  • Views 1.2k
It should just clip off mate
Take off all grab handles and sunvisors.
Pull off all the pillar trims.
Pull down the interior light from the edge and let it hang.
Pull down at the edges of the roof lining carefully so as not to bend or deform it.
far does, it cliped? or just perfect fit?
its just held in by the various screw in parts and then just held in by the seals.
its easy just have a go, took me no time at all!!
yerr polomon is right, i gave samR a hand yesturday taking his out & it was really easy when you jsut work it out as you go along, its all just clips & a couple of screws
far does hen might have a pop.
