Mk2 Polo LX
I have a mk2 polo LX and i'd never been able to find it on lists of models on glasses etc
Found out, when i went to go pick up a part from steve (86c) that the LX was only made for one year in 1984 (A reg) and was a pre-model to the coupe s, so basically a coupe s with a squareback shell on it
Any more LX's on here? any idea how many would have been made?
All info welcome :)
Edited by Matt_Oldfield
Only one I know of is Bort's, I think it was late reg'd so is on a B-reg.
They were the full on top spec car, above GL and CL. The same-age precursor to the tp the Coupe S was the Coupe, which slowly built up to Coupe S spec.
If you have a look in the member's section, there should be a brochure for your car and others of the era.
Thanks Mate, thats cool :) I thought it would be because of the little bits and peices it had that seemed higher spec than others i'd seen :)
