De-Wipering 6n2
Quick question, how hard is this to do ? i used the search function to try and find a guide of some sort, but i cudnt find one, just wanted to know how hard this is to do ? and how long it'd take, thinking of de-wipering mine as my rear washer doesn't work so figured might as well take the whole wiper off, is there a 6n2 guide floating about anywhere ?
cheers for any help
Sonic
  • Views 944
is there a picture floating about of what bolts to undo or what hoses to tie up and whatever ?
cheers for any help
Sonic
bump ?
Piece of piss.
There is a little cover on the rear wiper, it flicks over to properly reveal the nut behind it.
Undo the nut.
Then take off the black plastic cover on the inside of the bootlid.
It has a couple of torx bit fixings inside the handles. T
hen un-do the 3 bolts on the inside of the motor.
Then fill the gap with a grommet.
Takes about 10 mins
Edited by indy231
Piece of piss.
Undo the nut.
Takes about 10 mins
do you need to take out the whole wiper motor ?
cheers for the reply
