help finding grommit
I'm wiring in my sub, but i cant find the grommit to poke the power cable through on my mk4 8v polo,
any help??
thanks
chris
  • Views 1.8k
m8 i dunno if its just coz I'm tired but i didnt understand anything tht was said in tht thing lol,
i might just be stupid, its probs rite infront of me
chris
chris
Lol pull back all the carpet on the passengers side and look for a rubber bung, if you can't find it open the bonnet and then look for the bung in the car. If you still can't find it, look in the engine bay for a rubber bung on the firewall with wires coming out of it.
Right hand side of the engine bay as you are looking into it, down near the bottom. The large one with all the wiring coming out of it, pretty obvious when you see it, thats the one I used. Comes out on the inside behind the glove box
one problem there tho .... i dnt have a glove box i got an air bag :S
You'll probably have to reach behind the dash to pull it through then.
Pull back the carpet and look above the air bag on the firewall it will be a rubber bung, if you can't find it then you will need to open the bonnet and then look for the light from the engine bay.
If you still can't find it, go to the engine bay and look for a rubber bung on the same side as the passenger airbag. When you find it you could put a screwdriver through the bung then look for the screwdriver in the firewall when you look above the airbag on the firewall, then you've found where you can feed your live wire.
