GT engine cover
hi iv just bought a engine cover off a mk4 polo with brackets, just woundering do you have to have a certain rocker cover ?
also do you have to use the same bolt to fix the cover and the rocker cover ??
any pictures would help thanks
  • Replies 17
  • Views 1.3k
u dont need a certain rocker cover, just would'nt work on a G40 one due to it being very rectangle.
polo Mk2?
MK3
Mk4
i dunno about the bolts.
liam
polo Mk2?
whats the washer bottle in this pic??
top right
lol i know, i want to know what car its off.
possibly bmw
I think the washer bottle is out of a renault 5....
Check JimmyB's thread post no. 160 looks similar to his Renault 5 one.
http://www.clubpolo.co.uk/forum/index.php?...2210&st=150
Early mk2 washer bottles are pretty much as small as that, just a matter of fitting?
any no where abouts on the block the brackets go?
Edited by perrygt
mh,i like that cover.
does anybody know,if it fits on a aau engine?is it also available without gt badge?
should fit on a aau block, the GT badge is added on, its just a mk3 GT grill badge with the clips cut off then stuck on. the badge covers white "1.4" lettering.
hm,then i´ve to find out if its available with the 1.0... because i´m no liar :D
i´m just wondering if it will work with my round air filter chassis :/
yep, do it on 1.0l
lupo... great idea.i know a good lupo-parts dealer :D
Nova washer botles are rather small aswell :)
The brackets bolt to the hydraulic-type cylinder head,though the fuel pump gets in the way on stock pre-90 cars. The dizzy is also tight on carb models,and the cover rubs on the high tension plugs - i didnt find this a problem.
Here's the one i had on my 1.6 MK2 when it was an eight-valver..
still a lil confussed. any pictures with the cover off just showing the brackets ?
27 is the left lifting bracket, attaches to part 4^
Edited by jon H
