polo variant 6kv info
Hey, I'm looking to get some info as I fancy getting a polo estate. I know it actually has very little to do with a polo, its more a rebadged cordoba with a different interior. How low can you drop it without becoming a nightmare on speed bumps? What size wheels will fit? (They're 14s as standard aren't they?) Anything to look for when buying one? Cheers for the help :)
  • Views 961
  • if there out like the saloon mines lowered 30mm ish and if i have 2 adults in the back then the back end drags over speed bumps
mines lowered 30mm ish and if i have 2 adults in the back then the back end drags over speed bumps :shock:
height wise same as any other car.. coilovers are the best option so u can set up for road conditions.. wheels.. how u drive etc. 14"s 15"s 16"s 17"s.
6k chassic so cordoba.. ibiza.. classic.. etc. front end also the same as the vw van. just the normal things to look for.. a family car so normally clean as or battered!!
good hunting. ;)
david.
Cheers for the help guys. :)
They rust badly around the rear wheel arches....
