how to tint headlights
evening first off this is the way i did it, there are alternatives only have a few pics i seem to of lost them on my photobucket so i gathered what i can
1st step ,
remove the headlight from car and take out all bulbs etc
2nd step,
wait till your mum,wife,girlfriend arnt around and turn the oven on to about 100deg
3th step,
place headlight in oven for a few minutes checking it doesnt melt away,
4th step,
place on counter carefull use oven mits and a knife/screwdriver and remove glass from casing BE CAREFULL the glass could chip and get in your face!
5th step,
mask up the area you dont want sprayed black but dont press hard as it lifts the shiny reflective stuff
6th step spray them the colour you want, i used normal matt black spray cans a couple of coats should do although i would maybe suggest the heat resistant stuff thinking about it...
7th step,
remove masking tape slowy
8th step,
seal the glass on to the casing, i used black bathroom sealant
9th step, indicators,
i thought i would do the same for the indicators but its alot easier if you just spray the paint onto the shiny part of the indicator
result,
try something different
if you fuck up , on your head it be :D
  • Replies 16
  • Views 2.5k
nice little guide. think i know what i will be doing this weekend.
Check out the mad camber on THAT!!!
I've put a debadged grill on my car
looking great now mate :) , very good improvments :D . nice to see the nice rear lights back on too :)
jonathon
LOL! thats some crazy shit jizzurd!
Cheers for the guide mate. Might give it a bash!
them red tinted headlights certainly are different. Not quite sure how legal they'd be but are still cool none the less.
Why do you have to put them in the oven? :?
Such a good idea! :unibrow:
I'm going to crack on with mine!! :nod:
because the glass is bonded on and you have to heat them up in order to seperate the glass from the rest of the light.
Oh I see. Thankyou!
Might do this. :)
what do u seal them back up with? silcone?
As far as I'm aware yes :nod:
or you can use a heat gun which is what i used to do mine
nice results mate, how has it affected the beam? how bright are they??
Sometimes the glass can get slightly frosted when putting them in the oven or can look to have hairline cracks.
I used a heat gun to seperate my headlights.... Took a bit longer than using the oven though.
Be aware that you are dramatically reducing the intensity of the lights if you do this...
Mk3 polo lights are pretty shocking standard!
Thats what I found anyway, looks good though!
would laquring them before you put them back together not help?
  • 2 years later...
so.... what with the indicators? just spray straight onto them or inside? :lol:
