Headlining in a MKII Square Back
Has anyone ever removed theirs and replaced it? Was it a difficult job? Mind if i do it, i will be making my own lining, so how are the metal rails attatched to it? I would take it off to look, but obviously dont want to bugger about with it if i cant get iot back in! :lol:
H&S
  • Views 1.4k
theres sewn in pockets /tubes that the rods go in ...the edges are tucked around the window flage so side and front glass need to come out
Sweet cheers. How do you mean the front glass though, the windscree? I take it the rear glass doesn't have to come out, like on the MKIII's?
H&S
front screen and quater panel windows ...they're rubbered in , if the screen is chipped theres a good chance you bust it
Can i not just pull the rubber seal away (heat it or somehing to make more pliable?)? So the rear windows too? Is this how the professionals do it, cause it's an awful lot of faffing, or do they have some trick o' the trade?
I does have a wee chip in it, but it may need to come out anyhow for the full inside and out respray, hence the roof lining too.
H&S
the linings usually tucked right round so it is a window out job to get the new one back in properly.
is is easyer to push the glass out from the in side, just make sure you apply the pressure evenly and have someone there to catch the glass when it goes
