mk7 door panels
hey all i need some advice on how to take my door panel off, i know you have to remove the case on the handle which has two screws andi have to take the window winder off, but not sure how to get the window winder off.
any advice on taking it off, I'm not sure if you just pull it off or undo a clip.
any help would be good thanks
Edited by griff25
Hi, the actual winder, to take off, there is a clip at the base (near the door panel) that you have to be quite forceful with and slide towards the inside of the car, once this has popped open its just a case of pulling the handle off.
