Re-Spraying
Just looking for some suggestions on how to
re spray a 6n.
How do you go about it?
Buy standard rattle cans or hire a compressor/paint gun ect...??
  • Replies 14
  • Views 1.4k
You get a air compressor and a spray gun if you want to do it yourself, but it will be alot better if you get it done professionaly
please don't respray a whole car with cans, if u got a garage to spray it in, get a compressor.
i did mine in the garage with a compressor and spray gun. looks real good. just take your time prepping it mate, makes all the difference.
If you want a good job do not attempt to do it yourself unless you know what you are letting yourself in for. It is far from easy to paint a car properly and make a good job of it. You need lots of equipment, the correct facilities, lots of time and patience to do it well. Unless you know someone in the industry you may find it hard to get hold of the paint as suppliers often wont sell to the public. Spraying with 2pak accrilic paint is also very dangerous as it contains isocynate which is in the cyanide family, best to stick to cellulose for diy!
My suggestion is to do a fair bit of research into it and see whether you think you will be able to manage it, I'm not saying it is impossible to do it yourself and make a good job of it because it is possible but it takes alot more than people realise.
Hope this helps.. oh and one last thing - do not use rattle cans!!
Just curious guys...
Whats the average price for a full respray on a car the size of a mark 3 polo? I know it varys per area, buisness etc.. but rough ideas?
Savin i wouldnt risk doing it your self unless your preparred to not be happy with it because i cant see it being easy?
I wouldn't do it personally if your just going to do it on your garage at home.
Even with the correct stuff its really difficult to get a good job
You need shit loads of practise to get it good.
Doing mine soon by my self at college
I have access to everything I could possibly need to re-spray the car. I'm still not going to get a really good finish. Nothing like a pro anyway. And that's after hours upon hours of practise.
Rattle cans will probably be more expensive too.
Prep work. This takes hours and hours and hours.. Do NOT rush it whatever you do. you could be a master sprayer but if the prep work isn't up to standard then it will end up looking a right mess.
LeonL
For a decent job you are looking at 1K upwards really.
I'd be a bit wary with anything under 1K I think. Its a hell of a lot of work, and if they are doing it cheap, they are cutting corners.
I'm in the same boat as him!.. i do it at college have access to everythink etc, well did go but llast exam next week then level 3 complete and totaly agree with what he says!
if u know someone in the trade, £400 cheepest. it really does all depend on quality for 400 i wouln't say it will the best job.
I Had a full windows out exterior respray on my mk2 polo. 1300 pounds. took 4 weeks.
very happy with it. 2 years on it looks like a new car, and laquered so it won't fade to pink like it used to!
My advice is be very fussy and choose bodyshops very carefully.
One place quoted me a grand, but would have masked off the windows and trim! Not all bodyshops specialise in full resprays. look for one that does older/classic cars. they seem to work to a higher standard then ones which tend to repaint accident damage on vauxhall vectras!!
I asked for extras like getting the sills and areas under the bumpers rust proofed and stone chip protected, as it was when it left the factory. I also visited every other day to make sure they stuck to what i wanted!
In short, if you want a proper job, be prepaired to spend proper money at a proper place!!
I've just got my bootlid sprayed by a friend, rattle can job. The prep work wasn't 100% done but with a lacquer coat on top it would easily pass as the standard paint. Even though I got hold of the wrog colour paint as I didn't check the paint code cos its covered by a false floor lmao.
But yeah, fine example, a car can look good if not better than a proper job if done properly.
B-shaw is spot on the money. You need to spend hours upon hours on the prep to get a good job in the end. The longer you spend preping, the easier and better the finish coat/coats will be.
i think the answer is in your question..... if your having to ask then attempting to respray a car for the first time being inexperienced is a bad idea. it takes a lot of prep work as others have mentioned and if you don have the right environment to spray in then you'll spend twice as long trying to sort out crap stuck in the paint an runs etc.....
save up an get it done properly. :-)
Get it done professionally. It seems like it would be your first time, so you will more than likely make a mistake.
Howcome it needs respraying? In the same colour or a different one?
