PSD Mirror Polished Alloy Oil Catch Tank
  • Views 268
have you used this ? where did you mount it? and where is you put the out going to ? as very in need of one cheers Jake
sorry to hijack, i have a catch tank but still haven't fitted it as i dont no how as someone told me i need to block bits off??
^ if you mean for brm then best off posting in engine section or searching and someone will help you out
Tried that mate.
put a thread up in engine section for help?!
Hi Yes I have used this it was mounted under the coolant expansion tank.
Is your car a G40 if so then you really need to block off the supercharger boost return port with a blanking plate, an oil breather pipe can then be routed from the back of the block to the catch tank and then one pipe from the tank to the chassis leg so it lubricates the chassis. This can save on waxoil and stop rust!
jimmy any pics of fitted?
and i take it you didnt have to drill any holes?
I've also ebayed you a message cheers mate
