Would MK5 GTI stock 15" bbs alloys fit on 6n which has...
the reason i ask this is cos I'm running 14 inch wheels with 60mm down at front and 50 at back, and the front has barely any gap!! so if i put these 15s on will i get problems?!
please help people!
look at me car here
  • Views 1.4k
BUMP is it that harder question!?
Depends on tyres.
195/45 on there and you can go as low as you want,
i dont understand :-S
The wheel diameter means nowt when it comes to lowering and such, it depends on the tyre profile
It's the overall diameter you need to think about, for example 195/45 profile tyres on a 15" wheel are fairly close to the overall diameter of the standard 6n steel wheels
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
EDIT:
For example if you compare the rolling radius or overall diameter of the standard 175/65 13" with 195/45 15" they are barely any different
What profile tyres are you running on the 14s?
Edited by AMD_Man
iam down 120mm on mine and there is about 3-5mm clearance on the arch, with the polo gti wheels there offset is fairly high compared to over alloys so basically there tucked up in the archwell nicely.
thanks loads people, the current 14s are 185 / 55 / 14.
and so the gti ones will be lower profile and wider, awesome!
amd man, that tyre sizer is ace!
