Stripping MK3 polo for respray
Started taking everything to pieces so i can get everything sanded etc. My question is about the boot
Theres a wire thing either side that goes from the actual car to the boot....
Where does that disconnect? I don't want to have to remove any headlining if i can help it.
Also, the doors. Is it just the 2 big bolts on the hinges and they come off?
Oh and the sunroof, metal sliding one
Will probably be able to figure out but may aswell ask before I attempt it.
any help would be much appreciated.
Toby
Not sure about the boot wiring but the doors are the bolt/s on the actual hinge (can't remember how many) and you need to undo the horizontal bar thing that stops the door opening too wide, then they'll come off.
My best guess at the boot wiring is obviously that it's for the heater and wiper, but I doubt if the wiper plug at least will fit through those gaps... If it was me I'd rather cut the wires and crimp/solder them back together than take the headlining off!
If the plugs will fit through the holes though tie a bit of string round them going all the way through the metal so you can easily pull it all back through.
Trust me mate, take the easy option with that boot wiring. can be a right pain in the arse to feed the cable through again.
I only need the numberplate light and the rear heater things. I can get rid of all the wiper stuff.
I was thinking of cutting it then connecting um back up with some sort of crimps or whatever.
I'll have a go with it tomorrow and see what happens. That's if its not bloody raining again.
Done :lol:
The other side was the water for the wiper.. Which is no longer there. So that's gone
As for the wires, again i have no rear wiper so dont need to connect all of them back up. I'll just tape over the ends and shove um under the headlining :lol:
With some of the wires gone ill be able to get spade connectors (or something along those lines) on um and into the rubber thing without a problem. Job done :D
