Replacing the front windows
I need to replace the driver's and passenger's side window, but not sure on how to do it.
Can anyone give me any tips?
Thank you
Mike
  • Views 1k
why you gotta replace it mate ? , someone break it ?
Front tints for the mot mate
ah right , well are they proper tints then or is a film on the inside , cos u know tints on the front are illeagal anyways , better to be safe than sorry mate :)
Anyone know how to remove the passenger and driver's side windows?
If your on about the door windows and its on a 6n?
Firstly you will be wanting to Take off the door card and put it somwhere safe so as you dont break it. Put the window down a bit untill you can see two brackets with rubber inserts holding the window. There sort of a clamp. There should be a nut on each one, 10mm IIRC. Anyway undo both of these untill the window comes loose and then it's just a case of pulling the window out. Pull it up from the outside of your car and with a bit of manovering you should get it out. Make sure you don't drop it!
It's fairly easy. The hardest bit is getting the door card off without breaking anything :lol:
Jake
Thanks mate :)
Thanks mate :)
Glad to be of help :-)
Jake
