DIY debadge grill HOW TO.
thought i would have a go at a how-to.
debadged grill! mk3 polo, but i assume it would be same principle for anything really.
tools needed -
junior hack saw
couple of loose hacksaw blades
stanley knife
sanding paper
soldering iron
peices of card for templates
pencil
2 grills of same spec - could use anyplastic i assume, but would be a more lengthy process.
so i managed to get a spare grill. so i had two grills
then i sectioned the spare grill and cut a section out of the right side of it (then if i made a mess at least i had the left side to try with! i just used the junior hack saw, taking my time and trying to keep them as straight as possible - makes life easier later on.
then i bit the bullet and cut the badge out of the original grill - no going back now! i measured the section i had cut from the spare grill and used this as a guide to how much i needed to cut out of the original grill, i did cut the original grill hole smaller to allow for trimming and adjusting later on.
so i had this /\ /\ /\ /\ /\ /\ /\ note i didnt cut it as straight as i could have done so i had to mess a bit more with trimming to size.
i ended up with this, you can clearly see the difference in size between the hole and the filler. again all i had used was the junior hacksaw and the loose blades to get into the difficult bits.
not the semi circle gap at the bottom which needed filling, so i used a spare piece from the old grill, made a card template and copied it to the plastic with the pencil and cut it out with the hacksaw and trimmmed it with the stanley knife.
i used some of the off cuts of plastic and my solder iron (gas one) to melt the plastic into the gaps and join the two parts together, i did this all from the back/underneath so it wouldnt be seen from above when fitted to the car.
then i trial fitted the filler into the hole
it needed some trimming, no pics! trimmed it down to size and tried it again
so once i was happy with the fitment of it i started to melt the two pieces together, which was easier than first thought it would be, i melted the plastic and pushed/smoothed one part to the other part to increase the strength, started by doing a bit on one bit then a bit on the opposite side to keep it straight and equal.
i did each strip till i felt it was strong enough - note i used a piece of the old grill which still had the strengthening bar going vertical, which i feel has kept it rigid enough.
an almost finished article
and the rain started getting a bit much, so i put it on the car until i can get back outside in nice dry weather, as i think it needs a little more work at the top, a bit of filler and some black spray paint.
so there will be more to come in the finishing stages - this is not finished, but a very good start to the finished article and will stand up to a glance view but not close scrutiny, but hey it hasnt cost me anything!
on the car
will add to this when the weather permits.
to be done - remove from car - fill the gaps with some body filler and a light sand and then paint.
comments welcome.
Rick - P.S this is my first attempt at this kind of thing.
okay . . . update, got round to finishing this and spraying it.
bought some primer and spray, had some filler knocking about.
so i removed it back off the car and set about finishing it properly.
i spread some filler in!
sanded it down a bit and then filled some more!
so i was happy with the look and felt i would give it a blast with the primer, it did show up a couple of omperfections so i spread some more filler where it was needed and the wet and dried it.
wet and dried it back again after the final coat of primer and then went at with satin black
and then on the car once dried.
I'm pretty chuffed with it. first one i have ever had a go at, cheap mod to do, reckon it cost me less than a tenner and if i was to do it again, i would already have the stuff, so be cheaper!
Edited by humer
  • Replies 12
  • Views 1.5k
Nice guide mate :)
Will help alot of people
good pal, like to see what it looks like after u have finished!!
ill try and get it done through the week when the weather improves!!
any ideas on what paint to use to paint plastic? i have seen poor attempts of painted plastic and it seems to peel off after a couple of months.
thanks for the comments!
make sure u bang some primer on mate
light sand to give it a "key" and then primer/paint? thanks.
yar mate, u havin it shiney or matt
prefer matt so it doesnt stand out, just want it to look standard but debadged! its only a temp car whilst i shop for something. but i can see me keeping this and doing something different with it, already got some bike carbs and a manifold being made! but its out of mot in two months and ill see what it fails on before i go mad!
so matt black paint. . . . or camo vinyl to go with the roof!!!
i know, but non were about and each one i asked about had already sold, so couple of hours anfd i had my own, cost me 1.39 for lighter fluid!
if i keep the car and this one doesnt turn out very good, ill buy one. but dont want to spend money on this car just yet!
finished the job!! all sprayed and back on the car!
been doing this now. . . .
again, another free mod, liking this polo, much cheaper to mod than my old golf!
just trying to figure out what to do with the number plate at the back of the loon. want something different there, but no idea what. might try welding something.
does plastic welding require a fair bit of skill? do you just melt both sides of the joint then in effect just melt some strips of plastic between them to join them?? youve done a great job there
basically this is my first time and i can only tell you the way i did it.
i cut the grill using a hacksaw, then i got everything to size and used bits of the old grill that i cut and melted a couple of bits into the gaps which joined the two parts together, lined each slat up and just a bit of plastic welding at the top before i could work from the back of it, i then melted more of the parts together from the back so it would not ruin the top, o then put a skim of filler in the top and sprayed it.
hope that helped. this was my first attempt and i just jumped in.
i used a gas bluepoint (snap on) soldering iron for the melting.
just go for it mate, whats the worst that can happen?
yeah its a great idea, I'm after a mk3 next so i will probably have a bash at this, cheers for the info
