Loose Wing Mirror
The Drivers side wing mirror is loose and flaps around. The mount is secure, but its the actual mirror that is loose. Had a poke around but couldn't work out how to tighten it. Is it possible?
  • Views 3.9k
Depends on model.
What car is it?
Depends on model.
What car is it?
Beginner error! It's a Mk3 GT Coupe.
GT - internally adjustable I take it?
There is a hollow shaft which holds the mirror to the mount within which the remote adjustment cables run. This shaft is held in place by an spring washery thing (lovely technical term for you there!).
On my passenger-side wing mirror the end of the shaft had rusted and the spring washer fell off, making the mirror move all over the place. Check this first by simply unclipping the section up plastic underneath the mirror mount.
Had a look under that cover but couldn't really work much out. How do I go about fixing it?
Same dude!
Mines just standard mirrors and my drivers side is floping.
Not loose just hanging downwards. :wasted:
