any one else smashing the sh** out of there
been driveing the polo for the larst 2 days and i have ripped the shit out of them just on flat roads there all bent up and these no metel left on the botem of the drivers side one 2day welded 3 2.5mm plats together and weled them on the mounts they seem to be takeing a nice battering and there beter then b4 but i want to raise the mounts about 1"
but driveing down to run to the sun next week so it will have to wate and i need a doner subframe and 2 wishbones first as well as mine is so bent up from the larst owner
its pushed the drivers side wheel about a 1" back
just wanted to no what you lot are doing with yours
cheers
loz
Edited by pre67
  • Replies 45
  • Views 2.9k
how about raise it up? whats the point of running your car so low it wrecks pretty important bits like your subframe and wishbones!?
i need a donner subframe
would you like chilli or garlic sauce mate? :p
hehe opps doner
yer was going to raise it up but it will change the caster and it will be harder to steer and if i dont get it perfect it will pull like a bitch
my mate said there was a thread about subframes raiseing ect but cant find it i put one up but no one replied
because it looks sick lol :-D
never seen anything about subframe raising, all you can do is weld some thick ass plates to your lower mount area and rebuild another subframe with thicker steel down the bottom (plate like a mofo) then refit the new subby and you rockin.
yer think i will just have to do it and see what it drives like just need to get me hands on a subframe naw 8-)
Learn how to drive. Dodge the potholes and bumps.
i can drive i would be fucked if i hit a pothole
it drags evey where even on flat roads
If it drags then raise it up. It looks daft anyway with poke like that.
cambers way out in that pic and iv not rolled the archs
and i dont want to raise it as looks sick as it is
might look sick but if your car is banging then you have to do it.
You sure it's hitting the ground, could be the chasis hiting the ARB or something. Maybe a bit of notching would help.
Rolling the arches won't do anything, you will need them pulling
I can't see any other way of defeating the problem other than raising it, or just using springs so hard that the suss doesnt travel at all! And btw.. how is rolling your arches going to have any effect on that amount of poke?!
why i hated 13s :(
pah i did this on 15's
dave thats savage! i dunno how u lot cope sometimes when i was down 110mm on 14's i couldnt put up with banging cats eye as it was a daliy so raised it slightly. also the drive shaft banging on the chassie leg that was also a issue
Yer my mk3 hits cats-eyes :( Scared the shit out of a cyclist this morning as i went to overtake :lol: The drift shaft doesnt seem to bang though, probably does but i dont know it :doubt:
Edited by Olly S
If it drags then raise it up. It looks illegal as fuckdaft anyway with poke like that.
impounddddddd :arrow:
Dont run 13's on a 6n if you're concerned about the underside.
I borrowed my mates Classics for 2 days, with coilies all the way down, hit everything, found myself scraping the floor on just random unlevel roads.
Pointless really, the stance on 14's is miles better and i rarely scrape now..
Higher it or deal with it I'm afraid, i had my mk3 down quite low and it was the worst drive I've ever had and cannot understand how people drive them that low. didnt even handle well either in comparison with how it does now.
Caused damage to steering rack, drive shafts gearbox, front bumper, bodywork the lot haha! Looked great but can look just as good on a decent set of wheels that fill the arches! Found with my mk3 that the drive shaft just sat on the inner wing and when going over a bump there was no travel which caused me to have little or no suspension.
yer thats what mine looked like but iv welded it all up naw
get a arch roller and roll the liveing shit out of the archs and it will flare them
most people use them to just roll the lip up just you can get so much more out of them
if it drags but you dont want to raise it.
then make do with changing/ welding wishbones up!
Oh, and on another note, you said you drove this!
You complete and utter contradictory son of a gun. IIRC you told us lot that you wouldn't be so daft as to drive this car in that state...it seems you have.
Some things are borderline legal such as my stretched tyres ~(I can get done for construction and usage but blah, its nothing major) but to run with THAT much poke is ridiculous, if it was a slight bit fair play, but christ man. Do you seriously want to lose the car before its finished?
