Noob question re: engine upgrades
I have upgraded my 1600 polo to a 1800, now I've taken the next step and upgraded to a 2L engine. The question is: do I have to upgrade the computer box and if so which box?
  • Replies 8
  • Views 1.2k
I dont know anything about this, but i imagine the general response will be which 2l? engine code?
I'm not 100% sure really but it the 8 valve one, I hope this makes it distinguishable from the rest.........
I suppose a more generalized question would be(covering all engines) - When upgrading engines in the VW polo, do you need to upgrade the computer box too?
if u swap the engine the ecu (computer box) will need to be changed as well as the loom etc for the negine to work
I understand the ECU but why the whole loomb, everything seems to be working fine using the old loomb??
ok well u never said what 2.0 engine etc engine code bla bla bla if it works whats the problem?
sorry not tech minded, haven't swapped ECU and feels like engine is not giving 100% yet, so needed to know about ECU, thanks btw will look for a 2L ECU
do you know if it is 100% neccessity to get new 2L ECU, why the upgrade. Need to confirm machanics choice to leave old 1600 ECU in place. Sorry for being a pain in the a__
Noob
