Taking off door handles.
How do I go about it?
Will it interfere with central locking/alarm?
Taking them off to spray.
Cheers,
  • Views 985
I think you have to take the door card off and look inside near the handle then unscrew the bolts
And would I need to mess with central locking at all?
I don't think you have to, but if you do look at the way it's wired up and screwed on before you mess with anything so you know how to put it back together.
The exterior handles? Dont take the door card off. Above the catch, on the door is a screw which goes into the handle....Unscrew this and push the handle towards the front of the car and pull it should slide out (unless its a mk1-3 where u will need to take the insert out of the handle and release a screw there)
:thumbsup:
:thumbsup:
so unscrew it from the inside, then push and slide? Out of curiosity, for my mirrors, I'm doing 3 coats primer, 3 coats spray paint, 3 coats lacquer. Same for handles?
