1.0 with 1.3 head?
hi peepz just wondering if the 1.3 head will fit on the 1043cc engine???
so i can cam it up and have bigger valves.
regards ali
  • Replies 13
  • Views 1.5k
as far as i know the haeds are the same.
i put a 1.3 head on my old 1l ran fine, no differance on power though
Its the throttle body you want to change for a 1.4/1.8 Spi Mk3 golf unit ...
They are the same upto G40.
Even the g40's had the same head, just that different rocker
H&S
But they had sodium filled parts whereas the lesser models dont.
What did the sodium do? I know of someone who 'converted' a GT block to g40, no probs. Structurally (dimensions, bore etc.) they are the same though right?
H&S
Helps with heat dispersal iirc.
Ah right, interesting. Cheers. There was a discussion about the differences in g40's an normal 1.3's on polog40.co.uk, some said there was added strengthening, but i cant see vw doing this. I assume its not essential though, since people have converted gt's to g40's?
H&S
it can be a damn good idea to strengthen them as plenty seem to crack around the inside of the front legs :-(
The metalwork maybe abit thicker than other 1.3s but just harder to spot.
the 1.0l's have smaller valves apparently...
They do, and smaller ports. I wouldnt want a 1.3 head on 1.0 for daily usage though
yeah fairly sure the 1.0 heads have smaller ports and prob smaller valves too.
Coul you make the ports larger? And also the valves, is it just a case of larger valves, or larger seats too? what about the 'holes' they sit in, do they need to be bigger too?
H&S
