1.4 8v port and polish
does port and polishing a 1.4 8v have much of an effect in noise,reliabilty or power?
let me know thanks
  • Views 1k
let me know thanks
depends on if you have other mods for it to benefit from! ie cam and induction change... on an otherwise standard motor you would notice very little change in all of the above!
and on a tuned motor, it wouldn't make any difference to noise!
always wondered about this myself, where can you get it done? expensive?
you want to get it doen by an engine builder... i'm sure google would bring up local ones or someone on here who would have had previous experience!
with the polishing, you don't want the inlet to smooth as a little turbulance help the air and fuel mix... exhaust can be shinier than a school boys knob though!
and the porting needs to improve the air flow, DIY attempts can actualy worsen it! :cry:
you also need to get each one matched, so going to someone is better than a home bodge...
not sure on price, but i wouldn't bother unless your building a NA screamer!
