Did the 6n's (mk3f) come with Petrol Warning Lights
I ask this as mine has never come on then i just came to the conclusion that they dont actually have one yet cars the same age or older do?.
  • Replies 26
  • Views 2k
I can Confirm my 6n does have a Petrol Warning light, maybe you have always had a reasonable good amount in the tank??
Depends, I think it was the 1998 and onwards models that do as the have a different dial setup to the pre 1998 ones. My 1997 6n doesn't have a petrol light but my old dots 1998 one does as does my friends...
mine was produced in september 97,
and has petrol warning light.
comes on right on the first red line:( i hate that light.
mines a 1996 and does not have the petrol warning light
Iv got a petrol light but iv got seat ibiza clocks
-Edit- If you have the older style clocks you can have a petrol light the only resson you dont is the polo's did not have the blub in its the 1 on the right, right at the end i know this as i have ibiza 1s which are the same but they have the blub so i have a petrol light.
Edited by Po*Low*
correct if wrong but late 97 early 98 got the updated "newer dials" so maybe all those models have the light and the old dials dont?
the older shape dials in my old car didnt have warning light only warning lights it had was the airbag one on the far left under the heated rear switch
Well my 6n is an 'M' reg which is 95, basically one of the first 6n's and it does have a warning light.
my 1996 doesnt, i have run out of petrol before i think you can go around 14 miles with it driving reasonably when it doesnt move when u turn it on lol :)
o and it does come on in the earlier models, when u actually run out of petrol lol helpful as fcuk lol
Edited by witherz
my 95 n plate has'nt got one my 97 r plate has
Our T reg has. Makes me cringe everytime it comes on too.
So we reckon its on the New Style Clock with the Dials in the middle not at the Bottom ?
No, because I have a '95' reg which is an 'M' one of the earliest 6n's, early clocks too and mine does have the warning light.
sounds like its random if you have one or not. I dont, on a 96. the dials look exactly the same as the clocks in my old 95 6n, but the unit is designed differently, its LEDs instead of bulbs. (if that makes sense)
I'm gonna open her up like and see if it just needs a bulb in there. not that it would make that much difference. i fill it up to the very top and run til I'm completely empty!
my p reg does not
the R-reg (aug 1997) 6n I used to have had one.
Is it the case that the ones with the earlier style dials (with the temp and fuel gauges to the outside) dont have the petrol light and the later style with the fuel and temp gauge in the middle do have the warning light? I know the changeover for that was sometime in 1997 (in the uk at least) and my 6n had the later style clocks.
think ime going to pull me dials out and see if there is a space fora bulb in there on my 96 6n
just out of interest what else did they change on the update along with the clocks? i know its off topic and i appologise in advance!
Jon
headlight adjuster
Thats was i said previously with the newer* clocks with all the dials in the middle would have the petrol light but now this doesnt seem to be the case how wierd is this lol, i think i will look at my clocks again see if there is any bulbs for petrol light.
well I've pulled me clocks out and defo can see a space for a bulb but its blacked out on the other side so no cant have a low fuel light I've got a n reg 96 6n polo. just had another thought is the milage stored on the clocks or somwere else?
Edited by dubbegood
Stored on the clocks so it doesnt matter if they disconect.
wont the stuff they used to black the space out come off? Worst comes to the worst a lil black marker/paint will see it right.
i think this may be a model thing id say 6n L's have no light
CL's and 16v's should have em
GLX should have em
I'm putting a light in the then is it the same size bulb that goes behind the heater dials????
Edited by wheelmanWayne
