Dismantling 6N (mk4) wing mirrors
Hello there,
I am trying to fix my friend's mk4 Polo as she had her wing mirrors kicked off by a chav. I've purchased some 2nd hand electric mirrors from eBay but they are the wrong colour. I could paint them but I was kinda hoping I could use the base plates from the replacement mirrors and the original coloured case/motor/glass assembly from her car.
Is this possible and I would i go about breaking them down in order to do it?
Many thanks,
Chris
  • Views 1.3k
someone?
Cheers, but I've got the glass off them but i can't see how the case attaches to the base plate. If anyone knows I would be grateful.
i want to know this too..............
Ok, this is easier than you think. The plastic covers do come off! If you hold the mirror in a normal (ie on car orientation), grasp the lower lip of the plastic and pull forward. Then gentle pull upwards and it will disengage.
This will leave you with two bits: the plastic (coloured housing) and the mirror assembly still on the base plate. You can then further dismantle as required.
PoloD.
