door seal leak on polo 6n
i have replaced and re sealed the plastic door membrane, and fitted a 2nd hand door seal but on heavy rain its still getting wet inside car , it looks like the water is either running through the door and over the door seal or its leaking through the door membrane and running over the seal is this a common fault on a 6n and would a new door seal cure this or has anybody any ideas,,
  • Views 2.1k
You need to pinpoint exactly where its coming in.
Take your car to a jetwash and sit inside watching for water while a mate sprays round the door.
i can see water dripping over the door seal into car, its like the door seal is too low or its been compressed, when i open door after its been raining there is water on top of door seal,
i had the same problem , if you door membrane is ripped or not sealed properly then water will leak through it and in to the footwell, mine was piss wet through . I changed the seal first and it was still coming in so the membrane got changed next .
  • 1 year later...
I have the same problem when it rains i can see water dripping out of the bottom of the door card. Does replacing the mebrane work and where can u get them
Thank
