1.0 Carb to G40 Engine Conversion
I know there is quite a bit of controversy surrounding this subject, and i wondered if anyone knew for sure. Since i have a couple of spare 1.0ls, and fancied the challenge of converting one of them
These are the things I'm pretty sure of:
Different stroke
Deeper dish of g40 pistons (to lower comp. ratio)
Diff cams
Fuel injection etc. (including electrics, throttle body etc.)
Charger (Obv!)
A sensor in the bottom end (not sure what it senses, knock i think)
Things I'm not so sure of:
Block strengthening
Diff mounting point for the alternator
Other than that, I'm not too sure. I'm aware the electrics are completely different (being injection), but I'm kind of concerned more with various sensors etc. Such as that knock sensor, and lamda in the downpipe. Really am interensted in doing this, despite the difficulty. I know people will say ''why not buy a g40?'' but if i did buy one, i'd probs rebuild it anyway!
Replies and opinions welcome, and pictures of different blocks, heads, things like that
H&S
  • Replies 25
  • Views 2.7k
oh boy!
you need to send a PM to Hayesey as hes the oracle on polos
oh boy!
I have, on the g40 site, and still didnt really get a straight answer from him, and others on there. He was the one that pointed out the knock sensor though. I was just after some feedback from others, people always have random facts! Then again, if he is the man....
Thanks though for the direction
H&S
philj charged a 1ltr for a laugh, blew it up within afew miles, lower the comp and you should be good to go theoreticly
edit: his was an spi iirc
Edited by xcore
Ahh, i heard about this on the g40 forum, what a shame!
Well i was going to use g40 pistons, that should sort the compression ratio probs. Now its just the rest! I'm mostly concerned with using an ECU cause it needs all the inputs before it will function. I'd like to charge a carb engine, but I'm not sure which carb to use, or if i could achieve desired performance.
Oh, and xcore, I'm ratting it too! :lol: Only winding u up (or am i...?)
H&S
ren5 gtt carb should do the job no?
I have no idea mate tbh. What cars they from? Would i be likely to get reasonable power from that?
H&S
H&S
Oh wait, just re-read that! renault 5. Was that supercharged then?
H&S
renault 5 gt turbo carbs, they are designed to be used with forced induction and are probly the most avalible as a cheap ish price
Wicked, i'll have a look into that, might be worth doing something a little different like that too. Those buggers flew too!
Thanx for your help, food for thought. Do you know if its been done?
H&S
You can use a bike carb,just the one,with a charger. You'll need a fairly big one,at least 40mm,say from a V-twin or something.
You dont need an intercooler. You dont need injection. Or sensors. Or any other junk - just ignition.
The mistake i keep seeing is to place the carb between the charger and head,and thus try to blow compressed air into the carb. That's just silly. Instead,have the charger suck fuel out of the normally aspirated carb,blend the mixture,and blow said mixture into the head.
Yes,i am a genius.
Yes,i am a genius.
Mmmmm, sounds good. How would i get the air in 'after' the carb then?
That sounds like some hefty modding. Also sounds awfully thirsty. Worse than a standard G u think? If i'm going to do it, i want to eaton charge it too. But seriously, this sounds interesting
H&S
You simply place the sidedraught carb where the charger's air intake is. The charger sucks the mixture from the carb just like a bigger normally aspirated inlet port would,and blows it to the engine. If the carb is set properly,the fuel/air ratio will be correct,well mixed,and you'll have maximum possible efficiency. So it will be economical as well as nippy.
Having fuel passing through the charger would also keep it cleaner,and i speculate that the charger could last longer between re-builds as a result.
Its simple. You could use your standard carb manifold to distribute the charger outlet into the ports too,so construction costs/time will be minimal.
I only worry about your part - you only need a little charger for a 1.0, you'll be pushing it enough already with a G-lader designed for a 1.3, and i think that design will work better with the wet air,too.
Riiiiight. i was thinking of stacking the lot up and cutting a hole in the bonnet with a big chrome air intake hanging out the top! But i'm liking side draught idea, would probably easier, and cheaper!
I'm not a fan of G-laders tbh, the regular and expensive rebuilds really put me off. I've just been looking at specific bike chargers actually, although one was eaton-ed! MAD! Any other decent chargers i could try?
Also, any ideas on power? I'v seen some people getting ~100bhp with bike carbs on a 1.3, charging can only increase, but how much? Would you think it could challeng a standard g? I assume comp. Ratio would need to be reduced too?
So many q's i know, but this is food for thought. One last one, which bike carb would be suitable?
Thanks, this is a real help (or curse!)
H&S
Oh, and btw, i'll be changing all the internalls to g40. Con rods, and pistons (lower comp ratio) so the bigger charger wont blow the engine. I need to reuild it (as its done 120k!) so i'l do it proper like. Essemtially, i want a non-injected G40! May even bore out to 1,4 too!
H&S
Well that's how id be inclined to do it,the carb would be behind the offside headlamp.
Not that I'm not liking the idea of an Eaton on top of the manifold,with a twin-45 downdraught on top of it,and trumpets half way up the windscreen..
I'm not convinced the fuel would go through an Eaton as evenly,in any case.
A turbo would be best in theory,punching pure gas into the engine,but they get pretty warm and whilst a well atomised mixture is desirable,its nice if its not already ignited before it gets into the engine..
I cant really comment on G40s as i have no experience of them but whilst injection works well new,it can be inefficient when there are a few miles post service. One dodgy sensor and its flushing fuel - my bike carbs have never needed re-adjusting. There's a lot to go wrong with microchips,so i favour simplicity.
There was a 500cc jap sports twin cylinder in my local bike workshop last time i was in there,that's the kind of bike you want one from. Or one from any four cylinder sports bike over 950cc. The master carb in either case,obviously,so you've got your throttle-pull.
You might be interested in a subtle yellow Reliant Kitten in this months PPC magazine. Its 850cc engine has been boosted by a tiny Smart car's turbocharger. Not as relevant as it sounds,as its the conventional filter-turbo-carb-head routine,but its an interesting little feature on a group of alternative little cars.
Eaton maybe abit overkill considering the high boost levels they can run at! Think mines running 22psi iirc?
Hmmm, yeah. I'm not a fan of chips either, plus it can take a bit of the fun out of tuning as you can simply change the chip for a bit of power uppage.
As regards carb postition, behind the head lamp? That means the mixture has a long way to go, wont that add in some sort of lag on start up?
Ah, i see what your saying about the eaton, its not meant to be a wet charger is it? Any ideas which might be good? I'm not too keen on the turbo myself, as the engines are X-flow, and I'm not sure i can be bothered doing the pipe work from one side to the other. Maybe thats something to try after this is done
What bike carbs are you running then? And any other possible chargers that might suffice? Is there a good site/forum for superchargers in general, as i guess a wet one would be best?
Thanks agaain for everyones opinions and info
H&S
Keep the pipe from charger to inlet a small diameter,shouldn't be an issue. Better still,use stainless flexi pipe,usually marketed for exhausts - that'll stop the fuel collecting up on the apex like a water shoot.
But you're right,having the lot bunched up as close to the ports as possible is preferable. But getting a charger belt running from that side is the challenge. If you can piggy-back a drive from the water pump pulley,you might be onto something.
Thats what i was thinking of doing, but that means a longer timing belt, and all the added problems :? I also though bout adding a pulley to the crank somehow, but i'll need to have a look at my engine when i'm back.
BTW, why would a bike carb be best? And to make room for it all, i was going to remove the metal seperating the engine bay and heater matrix, could then possibly mount the carb on its 'side', as bike carbs are used to funny angles right? Either way, it would give me extra space. Also, why wouldn't it need an intercooler?
H&S
I think your right! btw, what does iirc mean? :?
H&S
iirc = if i remember correctly.
I'd stick with a G-lader for the time being to see how it runs etc. You could always upgrade in the future but you'll wanna make sure you can get hold of all the bits you need 1st! Can be abit of a mission (although i do have a spare eaton chip laying around :unibrow:)
Bike carbs are most efficient due to their technology - it took throttle bodies for sports bike manufacturers to replace them.
But yeah,they're designed to be tilted at a good 50-70 degrees,as opposed to 90 for a sidedraught. But thats easy to sort out.
You can see the angle of mine and Max_Crox's in the 'Bike carbs on a 1.3?' thread.
You'll also notice how much room there is there,once you take the massive inlet manifold out - you shouldn't have to cut the firewall panel (bear in mind the wider cylinder heads on ours). And with a piggy-backed pulley on the water pump,you'd use the standard cambelt - although extra strain on it means id do belt changes every 40k.
Yeah, once the manifold is removed, then it would be smaller, but I'm probably going to keep the standard one, and attach the charger to that. Unless you can advise otherwise?
As regards the piggy-backing, the belt would beed to be longer wouldn't it, since i have to get an extra pulley in there, and I'm unlikely to be able to get it really clse to its current postition. I really need to have a play.
If you were to super charge bike carbs, and it will be a 1.3, what would you go for? A 40mm choke, or is that too big?
H&S
About 40-45mm yeah,would only be using one carb. I know someone with 55mm's,though i dont know where she got them from.
By piggy-back,i mean a sprocket on a sprocket. So you'd have a double-decker pulley. Same cambelt but a second belt for the 'charger. You could put the 'charger pulley on the camshaft pulley,but given that it only runs at half engine speed,you'd need to gear the 'charger pulley accordingly.
