1.0 Carb to G40 Engine Conversion
About 40-45mm yeah,would only be using one carb. I know someone with 55mm's,though i dont know where she got them from.
By piggy-back,i mean a sprocket on a sprocket. So you'd have a double-decker pulley. Same cambelt but a second belt for the 'charger. You could put the 'charger pulley on the camshaft pulley,but given that it only runs at half engine speed,you'd need to gear the 'charger pulley accordingly.
Ok, i see what you mean by piggy backing now, i did think of adding a second pully to the crank.
so 40-45mm for single carb, what if i wanted a bank of four, ~28mm? Would it be possible to charge a bank, or would the advantages be lost since the air/fuel would have to go through the single point at the charger anyhow? That make sense :?
H&S
  • Replies 25
  • Views 2.7k
