smooth bumpers
my brov has a 6n2, he wonts the front bumper smoothing'
can anyone give use som tips!
  • Views 1.3k
Plastic weld,
Sand the bumper back to bare plastic
source some pieces of plastic similar shape to holes to fill them in (if you can find a cheap broken bumper in
srcappers might work
Use a sharp tipped soledring iron and some cable ties as the weld
Put the hot iron on the bumper heat both hole template bumper and cable tie together at same time
push the cable ties into soldering iron (heard the thick black types work pretty well)
Allow to cool
Flat it back
Usesome filler/fiberglass kit to achive contours
Now all you have to do is prep it for paint
Then paint
This is how someone told me how to do it but I've never done it due to time and money restraints
Practice on somethine else that's not important first tho till you feel comfortable!
If u mess up I take no responsiblity
or take it to a bodyshop and get it done professionally for 175 - 200 quid
Would look gay with just the front smoothed, you would need the back doing too
This is true it would be easy to fill in the bumpstrip recesses on the back and it would look pretty mint!
Edited by Pepe
thanks 4 the tips, il hav to get som qoutes from body shops, i think plastic welding might be a bit messie like ! :lol:
