THERE A LEAK IN MY FOOTWELL AREA!
I just cleaned my car and went for a drive,
and my window wipers came on on there own.
so stopped cause i looked like a idiot. haha
And i had water on my fuses, Why is this and where could it come from?
And then i noticed my footwell was soaking wet.
this is all on my drivers side.
Where could the water be coming from?
and how can i sort it?
And would it have damaged anything?
also i looked where my wipers are under the black panel. and there is wet under there with loads of muck crap.
could it be this and how do iclean it all?
cheers
shaun
  • Replies 10
  • Views 1.4k
the door rubber might be shagged mate, water may be seeping through the rubber and soaking up the foot well
but why would it be behind my glovebox on the 6n 16v, and in my fuses?
its oviously coming from higher up.
cheers
front screen??, maybe its coming from the firewall behind the dash then?
thats what I'm thinking,
but where coud it get in?
would it of damaged anythng if i drive it?
i would say when your driving water is coming from the engine bay and through the firewall into the internals. must be a open hole some where behind you dash
if its in the trough around the wiper mech itself check the drian holes on the far left and righ arnt blocked if they are water will build up and get in were the polen filter is
but the pollen filter is on the passengers side?
and how do i clean all the shit out of that corner?
why dont you get a hose n spray is around the area what may be leaking n get someone to sit inside the car and tell you when it leaks, should help narrow down the problem but then your going to get more water, i took my carpet out before i did this so it wouldnt get wet
take off the black plastic where the wipers bolt on to , under hear there is a black cable going through the fire wall , check the rubber gromit has not perished , mine did and it was pissing through so i sealed it up with gutted fix ....no water will get through that . hope this helps
I've got same problem but mine pass side, think mines because the plastic gutter at the bottom of the windscreen has bowed a little, il find out soon because I've just had new screen fitted so work will be free!!
