Little Advice on MKIII Wing Removal Please.
Hi all,
Got a massive dent in my nearside front wing. Happened before Xmas and, as I've nowhere to work, I've been waiting for some good weather in order to get it fixed. Paint's cracked a bit and there's a bit of rust forming, so was wondering if I should:
a) Take it off, beat out the dent and then treat the rust. Or,
b) Find a new wing.
Trouble is, I've got metallic (ooh, get me!) blue paint, so not sure I'll be able to find an exact match if I get a whole new wing.
I've searched the forum today to find out how to remove the wing and found reference to some gunk fixing it to the main body. Will this need replacing and, if so, what is it and can I get it from GSF?
As always, thanks in advance.
Fenris.
  • Replies 8
  • Views 1.7k
Hi all,
b) Find a new wing.
Fenris.
Well, it would be cheaper to get the wing off and beat the dent out. But how big is the dent? You might not need to take it off. Get some pics up
And i wouldnt go to a dealer for a replacement, it'd be cheaper to go to a scrappy. Prep and prime it yourself (if your confident) and get a body shop to spray the metallic. There's more than enough info on here to help ypu prep it if you choose to. And if you do it all before putting it on the car, that would be cheaper too. But beware, i wanted my door resprayed, and with me prepping and priming it off the car, and spraying in white, i was looking at over a 100 quid, and that was mates rates chash in hand.
Hope that helps
H&S
It's quite big! I did get one of those dent pullers, but the dent's far too big for it to work, so looks like it's got to come off. :-(
Here are some pics. Apologies for the state of the car, the weather's been awful in Gods Waiting Room lately so no chance of a spring clean as yet!
There is a technique for etting dents out, as long as the metal isnt bent beyond its 'elastic limit', i.e. is stretched. It may be worth giving it a go, since it works on big dents. You need to get some canned CO2 and you basically heat the dent with a hair dryer for around 30s to a minute, not too hot to damage the paint mind. Then, with the can UPSIDE DOWN, spray the CO2 onto it for around 1-2mins. Then, as it cools, the dent pops out. Shouldnt cost more than a couple of quid, and i've seen it work on big dents
Could be worth a short for a few notes
H&S
Ah yes, I did see that when I was looking for a quick solution. There is, however, one minor problem with this; when it gets cold again, the metal contracts and the dent pops back in! Lol! It's a great fix for warmer countries (most of the forum posts/You Tube videos were from people in America) but I don't think it'll work in jolly old England. Although, I'll happily stand corrected if anyone's managed to get through a winter with this fix. :-D
theres 4 bolts under the bonnet
and about 3 under the wheel arch that are covered in shit so you can't get a spanner around em, and thats after you've gone through the ballache of pulling out moves from your old Twister playing days to get the wheel arch cover off
and after that it's held on with adhesive that ican't remember the name of
but it's alot easier putting the wing back on if you have one todo so
Yeah, i'm pretty sure one of the guys on here (or one of the other million forums i seem to be signed to!) have usd this to great effect. In the end, its a couple of quid and less than 10mins to try, could save you a hefty bill. Plus its summer on the way, it will be months before it pops back in again! :lol:
H&S
H&S
Argh, but then I'm back to square one with it being winter and not being able to fix it! Lol! But... Humm, yeah, I could give it a go. Now, this'll sound dim, but where would I find C02 canisters? :oops:
@ Punkins: Thanks for the info, sounds like I'll need some good luck getting the thing off then! I was going to give it a go today, but since I need the car for tomorrow I'm glad I decided to seek advice first. :-D
H&S
I'm actually not too sure where to get the co2 from, but any compressed gas will do the same job, the compression makes it cold. I have a feeling air horns have them though, you know the sort? I'm not so sure it will pop out though tbh, since it already in a state it shouldnt be in, the metal is under more stress now than it was when the panel was straight. Heating and cooling just allows it to overcome the forces preventing it from straightening naturally
H&S
