Polo G40 big valve head - Sold!
It has done a maximum of a couple of hundred miles after being converted and operates with no issues.
Brand new Tappets – not been run at all
Brand new oil filler cap
Sand blasted and sprayed rocker cover
Brand new VAG rocker cover gasket
Brand new rocker cover bolt washers, rubbers and caps
All you need is the cam of your choice and some rocker cover bolts and you’re good to go.
£600 ONO
Postage can be arranged but the cylinder head is not light and is obviously a little fragile.
Edited by HenryG40
  • Replies 10
  • Views 536
can you post a picture of the Face of the cylinder head where i can see the valves :) ?
how much bigger are the valves compared to normal ?
the exhaust valves will be 2mm bigger. the inlets will be standard.
what is this like for performance ??
i guess that the flow would be better and the gases can escape quicker?
but figures talk :)
plus 600 is alot to spent on something that might only be slightly noticable
BVH will be suited very well for a turbo conversion because to get good noticable peformance out of it you will need to rev the engine more which doesn't suit the g-lader as well as the turbo.
using it with a g-lader you will gain some power especially if you are suffering from det on a standard head as you can get rid of the heat more efficently.
i wish i had the money to buy it but there are no funds!
i would guess it would give a few ponies extra.
x2
Would suit my spec sooooo well too. MAybe in a couple of months..............
it seems 600 for a few ponies is economicly un reasonable for me..
although strangly i want this but find it hard givin i have g-lader still..
A BVH is the icing on the cake really. They don't give extra bhp on their own, but will compliment a full spec of other modifications.
Cheers Robin for answering the questions, as he said, the exhaust valves are 2mm bigger.
Will take sensible offers on this by the way.
Couple of pictures of the valves
Edited by HenryG40
Sold!
