mk2 golf gti seats
Will some mk2 golf gti seats fit straight into my polo or would i need to mod the subframes ect?
cheers
ash
  • Replies 9
  • Views 1.9k
cheers
ash
They will go straight in, but they sit a little high. The drivers seat is (well, on mine anyhow) height adjustable, and will go to the same level as the standard drivers seat. However, if you have tall friends, they may get sore necks! Modification is just a quick cut and weld to the 'back legs' of the frame, or you could use your old seats as a subframe. I actually put my passenger headrest through my windscreen earlier this year as i tilted it forward! So beware if you dont change the frames
Hope that helps
H&S
thanks for that helped alot, think ill put them in and see what they are like
Good. I like them much better than the standard seats, bit more comfortable. Especially since i'm tall, and the extra support under the legs is nice
H&S
do you know if the rear benches fit in too? or are they too big?
It will 'fit' but the mounting points are different. I just squeezed mine in, but with a bit of modding, they will fit, ad bolt in. If you dont carry passengers to often, i shouldn't worry about it to much, though mine do have a tendency to slide forward now and then.
H&S
i put the golf rear foam and fabrick on to my polos seat metal on ther rear so they fit perfect there nice seats for in the polos
Did you get it to fit? I couldn't get mine to. Then again, i lost patience with it!
H&S
H&S
yeah on the botom you have to trim the plastic in places but fitted sweet
H&S
Wicked, i'll have a go at that i think. My rear passengers have a wild time in the back atm! ha!
H&S
