Have i fitted them correctly - Check last post!
Sup guys i finally my Coilovers finally after so much trouble with them lol!
So now there sitting on but i noticed the Small Spring is really Compress is this ment to be like that or can you highten the Middle Blue Thing to compress the bigger spring I'm not totally sure, my traking is so out also which i will have to get sorted once iv settled on the height
(from floor to top of the arch to get a ruff guide)
Fronts; 58cm
Back; 56cm
I will need to change this in order to get a ncie stance but look at the pictures and see if it looks right.
Thanks!
Edited by LOGiCALX
  • Replies 23
  • Views 1.6k
It's meant to be like that.
yep its ment to be like that
As said above, it's normal...Mine are like that, you've got nothing to worry about! :)
Only problem I see is the huge arch gap while the helper spring is fully compressed :lol:
dude this can only mean one thing!!! you have lowerage lol looking falward seeing it deck??? on thursday!!
Well thanks guys i finally figured it all out and the best thing of all.... I did it ALL BY MY SELF!. I took it to a mate today to just double check it i need new front mounts but thats all :D
I'm low enough to get jack out as its still my daily car and i cant be arsed with agro... so its low then standard about 56cm rear atm Fronts are a little higher but going to lower it to give it a stance then get the tracking and camber done :D
Good job :thumbsup:
Post some pics up when you can.
Will do mate I'm still on shity alloys atm once the fronts lowered i will take pics gota cruise on thurs will make sure i take some :D
Guys I'm just kinda worried atm, does this metal plate need to be used on the collys, (for the fronts)
Cuz iv fitted them all now :( but thats what it said to do in the UK-Polo's Guide, although i might of fitted the metal plate upside down but i dont think i have, help fellow CP'ians!
Edited by LOGiCALX
I'm sure that little plate in the last pic is upside down... It needs to be the other way, i can remember as it was a mission to tighten the nut back up with a spanner because of that.
Doesnt the top mount go on after the bearing and then its all bolted down?
Well you got the ruber mount that sits on top of it remember and it all fitted nicely and i managed to get the bolts done up finally as well when putting the top mount on and tightening it all up.
Heres a picture from coilovers from kwijibo_coupe he's got for sale
I also followed the tutorial from UK-POLO'S
Edited by LOGiCALX
phwoar get yer jack out dean!!! good times. I've been waiting for this for so long, cant wait to hear you scrape!!
I'm low but i cant actually go any lower then i am now because i cant actually get the jack out from underneth how am i ment to lower it more!
erm... a low lift jack ? or lower it onto some bricks, then when the jack is out, roll it off the bricks :)
guess i will have to invest in to a Low Lift Jack :)
Pic as it stands atm (just taken)
got the after pic with the coilovers on ?
:p
lol so mean, my roads un even and my jack is hudge!. Once i get a low lift jack things will be rocking :D
Get it on the floor, no excuses. :D
Quit worrying so much.
Sorry but it comes natural to me, but thank you all for your help so far i cant wait to lower it more :D
Have you got the original scissor jack? if so use both jacks so you can lower it more
yea there in with the spare wheel i s'pose i could use them, i think i'll go with the bricks the idea.
nuh use the little vw jack lower it enough to get the normal jack out stick the one from your boot in wind it up so its tight then lower the normaly jack the the other one then its out sorted
