Engines in a MKII
Anyone tell me which ones (with gear boxes) fit, besides the obv. mkII and III ones without too much modding? A single bracket isnt of too much concern, but dont want to faff with gear linkages etc.
H&S
  • Replies 14
  • Views 1.3k
this topics been on hear way to many times
use the search function
or just look through the pages :retard:
Edited by PortsmouthBMX
Has it, i'll haveb a gander. I'm just too lazy! :?
H&S
You've seen the small-block options,there's not much else if you want it done this year.. Not that Polo engines are simple - there was almost no information here when i fitted a 1.6 with bike carbs back in '06,i got some support from Steve '86C' and 'Gaz' but nearly everyone else thought i was mad or lying.
So - Tall-block has been done but is serious hassle for little and compromised gain (picture one).
1.8T has been done in the front,I've seen no details of that but for a YouTube quarter mile run. Good luck with that..
The 1.8T has also been put in the back (picture two).
VR6 might be possible with alot of chopping,but must be alot of hassle for alot of compromise and weight balance problems.
Mid-mounted - Audi A8 4.2 aluminium V8 using A4/A6 longitudinal front wheel drive gearbox,has been successfully bolted in a grey MK2 Coupe. It wasnt completed in the end,but has been done successfully in a Lotus Esprit. Id use two sets of bike carbs,but i dont do Gas-guzzlers. Just wouldn't be practical..
Outside that,you're looking at other manufacturers (Vauxhall XE,Honda TypeR or Ford Duratec,as random examples) or bike conversions.
Or a jet engine - successfully mounted in a New Beetle (picture three).
Right,mso its abd, afh (?), and the other standard ones, oh and that 1.6 you did (what was the number?).
I'm not interested in a total front rebuild, dont have the expertise/money/motivation to total a car, and attempt a front rebuild. And as you've said before, the chassis can only handle so much power! For the price of one of those type of jobs, I'm pretty sure i could get an alright g40!
Cheers for this though, i need my options cutting back, cause i would have a go at the, all! :?
H&S
G40 is probably your best bet.
I've looked into it and its the easiest and cheapest (ish) equal to the amount of gain you get. 1.8T would be awesome but a lot of work.
I disagree. I've built a circa 140bhp 1600cc version of the AFH with household tools on an open driveway for less than 600 quid.
It doesn't need charger re-builds,and dropped in with no modifications whatsoever to the car - not even to the wiring,but for a starter-motor plug.
Think we can safely say thats cheaper,easier,and more powerful than a G40.
I agree. The AFH I believe can easily produce as much power as a standard G40 engine for much less cost. It is also pretty much plug and play. The major cost for mine was getting the Inlet manifold made, which you make one yourself and buying a new exhaust manifold. Mine is standard apart from a Lightened flywheel (£80) and SS exhaust system (Manifold £170) and bike carbs/Inlet Manifold (£285) the engine Cost me £200. But you don't need the flywheel or SS exhaust system. With it I know I'm producing more than a standard G40.
And as Mikey said it doesn't require charger rebuilds and as its running pretty much standard should be really reliable as well. I'm rather happy with the power this the engine is putting out so I have no need for any additional engine work I am no concentrating on suspension and drive train.
Perhaps we should have an AFH section at the Polo Show! :lol:
AFH is 1.4 16v right? How did you get 1600cc Mikey? Bored and stroked?
It seems i have several threads running here, but talking to the same people. You guys have too much in the way of patience, really is appreciated! :-D
H&S
Edited by prankstar2003
..You guys have too much in the way of patience..
H&S
Its a revolution,Max!
Patience? You're not wrong,untold personal research and development - you dont find out that an AFH front pipe,G40 rear section and 206 HDi straight-through centre section work perfectly with no welding on a MK2 without bloody patience,i can tell you!
And then i just come on here and tell you how i did it. :retard:
H&S
You wouldnt be as happy if you didnt have someone to share your information with! :lol:
H&S
Yeah,i feel an enormous sense of well-being..
200 for your engine max, I'm impressed. struggling to find one for less than 400! should have bought a crashed 16v i saw for 350!
As you should, you may be respnsible for helping in the building of one of the greatest polos ever! :lol: Ha! :lol:
H&S
H&S
Yeah - mine :lol:
