active sub wiring
ok so I got a 300w rms active sub and I'm gonna get some 4 gauge power wire and ground wire I've already got the RCA cable I have shed loads for my decks but anyways the amp part of the sub has a fuse slot in it so do I need to put an inline fuse in and also do I need to put a switch in aswell? Cheers
  • Replies 27
  • Views 2.9k
Use a 18gauge wire for the remote turn on, and put a fuse in the fuse slot on the amp and put a inline fuse on the power wire
Cool cheers as i expected! What if I don't have remote turn on? Do I have to put a switch in it or will it just drain my battery without one? How do I wire the power in nearly? Put it thru the gromet in the frontwall?
I think I will buy the wires seperatly instead of a wiring kit n save a bit of brass!
Remote turn on is done via a cable from your headunit, sends a signal down it when your headunit is on, turning your amp on too. It's not a physical remote.
Without a remote turn on your amp will not turn on with just a 12Ve + and Ground...it needs that signal to actually turn 'on'
Imagine it as your PC being plugged in, but doesnt turn on till you push the button telling it to turn on.
The remote wire from your headunit will be a thin blue wire.
If you don't have a remote turn on then the amp woudn't get a signal from the headunit to turn on, yes you put the power wire in throught the grommet. Depending on the power rating on the amp, you'll need the correct wire gauge.
For the remote turn on all you need is a 12v supply if you want a switch literally find a 12v source wire it through a switch and then run it to the amp. your amp will not turn on unless you have the remote part powered :)
Cool thanks guys I thought this was the case just wanted to be sure, next thing is I don't have RCA outputs so can I solder the left an right + side and the left and right - side to respective female rca?
You'll need a adapter if you don't have any RCA outputs on your headunit, the adapter connects to a ISO connector on the back of the headunit
Where do they connect to? Sorry for my stupidity I am just new to car audio I no a fair bit about normal audio tho! LOL
They connect to the back of the headunit in the connectors like the power wire for the headunit
Yes sorry I should have made it clearer what connections am I looking for in the ISO low out yes?
The adapter will just plug in at the back of the headunit in the ISO connector
Ah right so it has the rectangular ISO plug on one end and RCA females ont other! Right sorry my bad I thought it would be just 2 females with little wires and spades on the end to connect them in don't realize sorry!
Hope i've helped :)
Hope i've helped :)
Yes mate big time also am I better off going with 4 gauge for a 300w rms from boot to battery? Would 8 gauge be a strain? I'm just thinkin I wanna really neat job and I wanna push it through the gromet and though some pipng to the battery (will there be any pipng to fit it in, in a 6n?? There are also some grounding points under the side
Panels that have the rear wiper ground point would this surfice as an earthpoint?
Hope i've helped :)
Yes, use 4 gauge wire if you wasn't living far away i would of fitted it for you. So you can put the wire through the firewall you need to take back the carpet and look for a grommet and feed the wire through there. The grounding point is behind the left rear light where mine is grounded.
Edited by Mike1990
All the carpet is colin out for my new black one so the cables
Will probably be laid unet the edge of the carpet, you have been an ace help mate sorry for
My slowness haha just wanted to make sure on everything! Just one more thing
Can I connect both an antenna amplifier and the remote wires at the same time as on my hu they are the same wire and I am currently usin an antenna amp? Basically will it power my antenna amp and turn on my sub and amp? Cheers
Yes, it will mate :)
Sweet roll on pay day/Sunday and my next day off in 2weeks, I'll me you know how it goes man and thanks again! I may even do a little how to guide for dumbasses like me who have no rca on hu and active subs and crap car audio knowledge see how it goes!
Ok so just wondering where to put my fuse on the power cable for easy replacement, do I put it in the boot thinkin of screwing it to my enclosure and having all working parts in one place! Or do I put it in the engine bay? (thinkin it may get abit too hot here) or under the dash before it goes thru the gromet (not too accessable but probably look better hidden away) think it could look cool on the enclosure! Opinions please guys! Cheers again!
Wire the fuse into the engine bay in a fuse holder
Edited by Mike1990
Is there a reason for that or just the norm thing to do I'm not keen on screwing holes in my body tbh!
The fuse needs to be close to the battery, incase the current from the power wire gets to much then the fuse will blow. Then the current won't go into the cars electrical system and cause a fire
Right ok I think I'll use a stick pad to attach I then in the engine bay! Cheers again!
No problem :)
