whistling
I always thought my car whistles at 100 mph and strong winds, but now I see that it actually whistles at around 60 and onwards, but because I had my radio on it wasn't auidble. Now I see that it's simply not the case. Well anyhow, the car is just loud and it sounds like a hurricane!
what could be wrong? THe door seals look fine...
  • Replies 30
  • Views 4.1k
think all do it mate tbh, the polo now does it and the one b4 did, my mates does, i thought this but i just crank the radio up more and it goes
Sound deadening could help
Dunno, it's a fair bit louder than I'd expect, even if it's just a cheaper golf.
This is one of the things I want to do in any case. The whole car is loud enough as it is without the whistling.
How, when and how much would it cost is another issue though.
Edited by MehMan
mines just like a slight whistling noise like wind escaping through a tiny hole dont notice up to 60-65 mph
I tried to record the sound but it sounds as if I had the cell phone in a bag in the trunk rather than at the front. Really muffled.
In any case, this is really driving me nuts. Next up sealing the plastic around the door mirrors, they look like they might be causing trouble...
Edited by MehMan
could be caused by the wings / door being out of line....... well if one is to far, in or out it'll whistle. iirc
if u have a sunroof it will prob be that
Nope, no sunroof.
I'm going to systematicly gaffer tape the car and see what happens. Door mirrors first.
sure its not a wheel bearing, or your alternator belt done up too tight causeing the alternator bearings to whine.
jon
I'm pretty sure it's not a wheel bearing or alternator, because those wouldn't whine depending on the wind. If there are strong winds you can clearly hear the whistling come and go as the gust come and go. It's also very distinct, quite different from a belt or a bearing, like air escaping through a small hole.
Edited by MehMan
I think the door's a bit canted:
I've got it out by a 1mm on the top and in by .5 mm at the bottom.
Could this be the culprit?
wouldnt of thought the door would be creating that tbh. u could try going for a drive with someone and get them to have a good feel around your car to see if they can find where the noise could be coming from. otherwise i reckon your gonna be hard pushed to find where its coming from
Wouldn't be a bad idea. I tried gaffer taping bits around and it's no better actually.
Maybe it is this?
problems like this are usually hard to sort out, u might just have to learn to live with it just like all those other noises that polos have a habbit of making:P
loud music will fix this problem :thumbsup:
I think I have to revert back to my prime suspect, the door seals. The car was left standing for two days in the rain and when I opened it up today I found a drop of water on the right side. Replacing is in order then!
Oh no way, the original door seals from VW are 126€ a piece! A PIECE! Does anybody know where I could get them on the internet? I tried a bunch of sites, but no luck, they supply everything BUT the seals!
Scrap yard hunting is in order!
i have this when the windows are down and I've known it to be the gap between the mirrors and the car
wind down the window and block the gap with your hand!
the only fix i can think of is stubby dtm mirrors
so who wants to start a group buy of them lol
Edited by wheelmanWayne
what like a sqeaky dashboard?
Do you mean the small piece of black plastic that hides a bit of the window? I tried gaffer taping that to the car and no dice.
nah i mean the gap between the mirror and window about 2cms wide
That bit, hmm, might give it a go. GO GO GADGET GAFFER TAPE!
thats not a bad suggestion tbh.
p.s you should really tidy that plastic trim up abit :p
I know that's the only bit of polish I missed when I did it last week
I thought some one would mention that or the flys plastered to it lol
