hello!
So yeah, I'm new to this forum.. thaught i'd give you all a holla! :-)
i bought myself a mk4 the other week, its my first car and so far so good!
il get some pictures up as soon as i can be arsed sorting out my photobucket account.
been having a few problems with the head unit electrics and as I'm 100% useless with electrics i thaught maybe one of you would help me out?
i connected up my 6x9's in the back, had it all working, think i had a few dodgy connections and when i went to push the actual head unit back in i lost power to it and got a burning smell and since then i haven't had any power through to it.
maybe short circuited it or something, any idea's what to do pleasee?
cheers!
  • Replies 8
  • Views 722
u might have blown fuse pal, check em all behind glovebox under steering wheel,
cant remember which fuse it is though
Edited by clarkson20
Yer check all the fuses :) Could also be the fuse in the back of the headunit :thumbsup:
theres a good point aswell should be a red one poking out on back of head unit
checked and changed the fuses around, no luck :(
Are all the connections ok on the headunit power bit?
just make sure u have checked the fuses right, if they are blown the bottom of them should be black/brown,
Welcome to Club Polo mate :)
i sort have the same problem the back of the unit heats up loads and smells like burning, 6x9s work but not to there max ability I'm going to have a fiddle around tomorrow so will let u know if i find a problem, see if it fixes your to.
