polo 6n boot badges
i want to debadge my polo
will holes be left in the boot if i remove the badges or are they jsut stuck on?
  • Replies 8
  • Views 1.8k
You can remove the badges if you get a heat gun and heat them up then slide a credit card under them to remove them
and that just leaves the paintowrk there does it?
no holes in the boot?
You'll need to remove as much glue as possible then get some Tcut to make the paint more cleaner
you cant remove the main VW badge tho as it will leave a recess in the boot, do it like mine:
Jon
You can remove the main VW badge but the boot will need smoothing
thank you :)
my car looks awesome now :)
  • 5 weeks later...
is this true for the facelift model too?
Actually I did, thanks, and this is the thread i found.
