Difference between AFH and AHW engines?
Am looking for a 1.4 DOHC engine to put into the MKII. Both of the above were in polo's of the same era, but what is the main differences?
H&S
Edited by prankstar2003
  • Replies 9
  • Views 8.6k
No,they're very different.
The AFH is a sports orientated head with twin cams,each having their own primary sprocket and directly pushing hydraulic bucket tappets.
The other 16v 1.4 is a more low-emission tuned engine,also physically very different in that the inlet cam has a master sprocket (turned by narrower cambelt) and the outlet cam trails on a tiny second belt. The cams on this engine are strangely mounted in the cam-cover,and the valve-train is a system of hydraulically self-adjusted roller-rockers.
The 1.6 16v's all share this second,more complicated design,as well as some 1.4s.
Will the AHW fit? Cause been looking for an engine, and there seems to be more AHW's than AFH's around. I take it performance is vastly different too?
H&S
The 1.6 version has smaller exhaust ports than the 1.4 AFH but that's not to say the 75bhp 1.4 16v wont make for a nice engine in the right tune.
Probably better than any 8v 1.4,anyway.
Whats the code for the 1.6? Which would you recomend personally, since you have run both?
H&S
There are various codes,the 1.6 16v engine i had from an '03 Golf was BCB. But you cant use any of the Golf 16v's unless you use a 6n diesel box,because the bellhousing has a tall-block bolt pattern - even the alloy-block 1.4.
That's why i used the AFH block,it was just easier.
I didn't run the roller-rocker head btw,just used the pistons and con-rods out of that engine.
roller-rocker head? So you only used the block from the AFH? What head did you use? Did you fit the BCB in? I didnt think you could get the tall blocks into Polos
H&S
The 1.6 16v MK4 Golf engine is not a tall block,its a short block - fundamentally the same engine as Polo/Lupo GTi's.
Ahh, interesting. And it drops into a polo? Do you know the engine code?
H&S
I answered that about three posts ago..
