4 / 7 pin lights on a 6n
bought some new headlamps from a show at weekend for my 6n when i got them home they are 7 pin and mine are 4 pin is it possible to convert so they work on my car as the plug only looks like it removable if you remove the front glass ,
  • Views 698
The plug on the back of the lights should come out with a flathead, then as long as the pump for the electric dip isnt in the way then the wires should just pull out :thumbsup:
you cant remove plug from rear of light as there is only one notch, when you look from inside headlamp there are 4 notches you need to compress before plug can be removed
Did it yesterday :lol: On a 6n ? oooo are they not standard lights? I just used a small flathead and went round the edges of the plug gently and it pulled out :?
